electronics!!!!
Old Sep 11, 2008 | 04:19 AM
JMM's Avatar
JMM
electronics!!!!
yesterday morning I stopped the car in front of my son's school. when I opened the door to get out, the driver's side window went down!!
I closed the door back and I pulled the window switch, it went up.
I stopped the engine and got out and....the window went down. Did that 3/4 times, until I got fed up and headed to my dealer ( abt 120 km)
They checked it out and the diagnostic was : we have to re- program the window settings
How, in hell, the windows settings were de- programed in the first place?
answer: we don't know, it happens!!!
Just in case ''it happens'' to any of you that's the procedure:
with engine running and door closed.
you pull the window switch until the glass is fully closed and YOU KEEP PULLING the switch for 5 seconds.
you release the switch AND YOU PULL IT AGAIN for 5 seconds.
then, you PUSH the switch until the glass is fully down and you KEEP PUSHING for 5 seconds.
you release the switch AND YOU PUSH IT AGAIN for 5 seconds.
It should work
Old Sep 11, 2008 | 04:23 AM
shumby's Avatar
shumby
Chech out the TSB of DIY section you can reset it your self
TerribleONE453's Avatar
TerribleONE453
you dont even need to do it that many times.. has your battery died lately? or been close to dead? it is a safety feature so your not locked out of your car i believe...
Old Sep 11, 2008 | 04:12 PM
fbpem1's Avatar
fbpem1
those cars are easy to reset the window timing, close the door put the window down pull the switch make the window go up not on auto and hold it for 5 seconds, done fixed over with.
Thedbarz
33
Feb 9, 2016 12:05 AM
blazeplacid
Sep 17, 2015 10:50 AM
bostonmerlin
Dec 25, 2007 12:52 AM
