Recommended maintenance '08 37s 5AT
Old Apr 7, 2019 | 06:55 AM
jwhiteker's Avatar
jwhiteker
I recently picked up my 2008 G37s 5AT with 100k and was just curious as to which maintenance items I should check off my list first. It seems to have been regularly serviced from what I can tell.
Just going through the threads here it seems like it would be good to check/clean MAF's and TB's. Should I worry about changing rear diff fluid or leave it alone? And maybe a set of new spark plugs. Are these cars hard on ignition coils? Are there grease zerks on driveshaft and suspension joints?
The car seems strong to me. Everyone now has me worried about this oil galley gasket. I believe mine has some seepage. Smh. I usually do all my own repair work but this sounds like a nightmare and a lot of time under the hood. I'm not sure I want to lean over my G for 13.5 hrs!!
Old Apr 8, 2019 | 07:46 AM
jpowersjr2's Avatar
jpowersjr2
Go ahead and do the spark plugs. Coil packs don't need replacing unless one is bad.
Old Apr 8, 2019 | 10:17 AM
Baadnewsburr's Avatar
Baadnewsburr
definitely change the diff fluid, and clean the MAFs... doing the plugs wont hurt either..... throttle bodies may be a bit finicky if you don't have the patience to deal with complications that may arise doing the idle air relearn enjoy the car for a while and save it for later
Kris9884
Sep 7, 2018 03:45 PM
prichable
General Tech Questions
May 31, 2016 01:13 AM
Paul_G37
Apr 24, 2016 02:24 AM
MPdesign
13
Apr 7, 2016 10:29 AM
Jethro
May 5, 2014 05:54 PM
