high mileage synth oil
G37sPhoton, I think you'll be golden with 5w-30. Amsoil seems like a good brand, but so expensive. I think most people on here use Mobil 1 Full Synth, Pennzoil Platinum/Ultra Platinum, Amsoil, etc... There is a poll on here that shows what everyone uses.
How many miles do you have on your G? 1 quart every 3k seems like a lot with that oil. That alone would keep me from using 0W40. I probably haven't burned an entire quart in +200k miles, on the Maxima that is. I haven't burned any oil yet on the G, only 70k, but I don't anticipate it would/will be much.
Latez
I used Castrol Edge 5W30 for a while with good results, nothing major. I then also read about 0w40 and decided to try it out, Castrol Edge also. I've found it makes the valvetrain more quiet, possible since the cold weight is thinner so it reaches to the valvetrain quicker? I currently have Mobil 1 0W40. however, I have noticed that I do burn more of the oil with the 0W40 weights. About 1qt every 3000 miles. I didn't have this issue with 5W30.
I attached two of my UOS so you can read the comment they wrote back with. You can't wrong with either weight.
Latez
Latez
my $0.02....I'm past 175,000 miles (about 282000 kms) I have always just used a full synthethic no special high mileage variant, I used royal purple for years then switched to Redline 5w 30 about 80k ago or so...the redline makes the valve train very noticeably quieter and I have never burned/leaked any oil with either...my OCIs have always been quite short so that probably makes the actual oil choice less relevant....I have the M110s in my garage as my wifes care uses them but I've always stuck with the M-108s as I didnt want to cause an issues with oil pressure or anything (probably not even a valid concern), with short OCI's I'm not sure even the filter matters too much...the only preference I have is for the oil that gives me the quiter valve train...sometimes i'm surprized at how quiet the car is being so old and with such high mileage that its possible that it can run so quiet lol
Hey Hashim- thanks and yes, after much reading , it seems with shorter ocis a number of other factors become less relevant and that is a good thing for me. I do see where brands are swapped around until a satisfactory blend is found etc by the user, so as i have only used synth blend m1 5w30, sort of got the it works so why change it, but like the idea of a quieter valve noise, so adding RP to the list of must tries...reading your post at 175k, I still have a decent amount of oil changes and brands to try out..
also, did read about the larger filter and pressure but not sure entirely either, but good food for thought..thanks
ok cool, thanks , misread that but yep, read about redline and agree based on the posts i came across that it does work well with vq but Im more and more deciding on penzoil , but thanks
Mobile 1 synthetic, plain Jane type 0w30 winter, 5w30 summer. Napa gold filters only.
Change about every 3k or 6mo (seasonal change) which ever is first and kids allow. At about 3500 I can start hearing the lifters tick more than I like... can’t see going beyond that.
One day ill pull a blackstone, but lazy.
G37sPhoton (01-04-2019)
I'm a bit late to this thread but I use Amsoil signature series and change every 9-10k miles.
Oil is fine and car runs great (still only at 70k miles though).
My friend has a 4runner with 200k+ miles who swears by the Amsoil signature series.
4rnr
14
09-12-2013 07:45 PM
