Does it sound healthy? Is that sound normal?
Old Dec 6, 2018 | 11:26 AM
  #31
slartibartfast's Avatar
slartibartfast
When the throttle is whacked open, AFR goes lean momentarily, not rich.
Throttle hang used to be endemic in the late-70s and the '80s until car makers got the necessary hardware to make EFI work right. That doesn't mean tour G is acting correctly, though.
Old Dec 6, 2018 | 11:33 AM
  #32
Vq_Jordy's Avatar
Vq_Jordy
everytime I turn the car off and then I turn it on, it doesn’t do it, so the problem is ecu related , it has to be
Old Dec 6, 2018 | 12:00 PM
  #33
RMB5190's Avatar
RMB5190
Yea that's where I read about it but the most recent example was with a 2012 Yaris so I thought maybe it could be the issue being described.
Old Dec 6, 2018 | 12:03 PM
  #34
RMB5190's Avatar
RMB5190
Originally Posted by Vq_Jordy
I am the second owner of the car!! And how would you reset it?,if this is the problem, my car is a 6spd manual by the way just putting it out there!
I just Unplugged the battery (installed my grounding kit at the same time), cleaned my throttle bodies and after hooking everything back up I did the pedal position and throttle re-learn procedure.
Starts at :45s mark
My hope is, my doing this you will see the throttle RPMS react normally as his does (4:55 mark) vs the hang you experiencing.
cole10
Engine, Intake and Exhaust
13
Jan 13, 2018 05:04 PM
Jan 8, 2017 03:19 PM
Goonz
Dec 7, 2016 08:23 AM
Steve M
Nov 28, 2016 06:14 AM
