Air in cooling system or..??
Old Aug 9, 2017 | 11:35 AM
Bossman's Avatar
Bossman
I have a 2008 g37s 6mt I just bought it and I'm going to have the mechanic at the dealership who sold me the car look at it. The dealership told me the mechanic replaced the thermostat but I still get the p0128 code, and I tried to bleed the system the best I can. Bleeding did make a huge difference , but I'm not sure if the coolant is supposed to be topped off from the radiator because the reservoir gets past max on its own which I'm guessing the car doesn't need to be topped off.
when I remove the radiator cap when the car is cold the reservoir bubbles like a bunch of air is being released. Is that normal? , and the coolant is not at the top anymore.
I need help because I believe that the mechanic doesn't know what he is doing.
Old Aug 15, 2017 | 06:40 PM
kiseliok's Avatar
kiseliok
G37 Community Team
Find a different shop / mechanic. Not sure what else you can do other than flush the whole system.
Old Feb 27, 2018 | 07:57 AM
rudeboyride's Avatar
rudeboyride
Bossman did you figure this out? I have same problem!!!
Old Feb 27, 2018 | 08:59 AM
Here's a great DIY on site~
https://www.myg37.com/forums/d-i-y-i...placement.html
Old Feb 27, 2018 | 04:18 PM
saywat?'s Avatar
saywat?
get the coolant funnel thing works like a charm easy to use and let the system bleed itself
Old May 19, 2018 | 10:56 PM
rudeboyride
So i bled the system with the funnel and it seem to be a bit better. was ok for a few days then CEL again. Same p0128. I replace the original thermostat and replaced it with the aftermarket mishimoto thermostat but still having the same problem. really need help!!!
Old May 20, 2018 | 02:07 AM
tite_tite's Avatar
tite_tite
Is your Coolant reservoir bubbling & are you overheating?
Old Jun 4, 2018 | 08:29 AM
rudeboyride
Sorry for just responding . No i have no overheating, no bubbling at all. So now i am thinking its the coolant temp sensor. But honestly i have no idea where it is. I cannot find anywhere on internet where its located. frustrating man
Old Jun 6, 2018 | 03:32 PM
Surfnazi's Avatar
Surfnazi
It's on back side of the head toward driver side. Grubbs is emailing the part spec sheet that shows where it is part cost is 41 bucks
Attached Thumbnails Air in cooling system or..??-screenshot_20180606-143502_astro-file-manager.jpg
Old Jun 7, 2018 | 10:33 AM
rudeboyride
Holy Crap man.. So I got to take off the intake manifold to get to this thing? Man that sucks!!!!!
Old Jun 7, 2018 | 03:29 PM
Surfnazi's Avatar
Surfnazi
It's not that bad you might as well change plugs and clean throttle bodies while you do it
Old Jun 11, 2018 | 11:16 AM
rudeboyride
Really sucks man!!! but I cannot see any other issue it could be. Unless the Mitshimoto thermostat is not working properly
Old Jun 11, 2018 | 11:25 AM
Surfnazi's Avatar
Surfnazi
Make sure your drain line that goes to the over flow plastic tank isn't clogged
Old Jun 13, 2018 | 04:04 PM
rudeboyride
HUH!!! Ok i will check that. Thanks. Any other things I could test before taking the intake off
Old Jun 14, 2018 | 06:33 AM
Surfnazi's Avatar
Surfnazi
Replace radiator cap
