Wiper Refills Important Fact
Old Jun 8, 2022 | 05:57 PM
  #31
Lith808's Avatar
Lith808
Originally Posted by Selym
The Honda refills are compatible.
If you need the whole assembly, you'll have to buy it from an Infiniti parts dealer. Do not buy the "Infiniti Maintenance Advantage" wiper blades. They look the same as what you need, but they are not refillable.
Got it! Thanks for the reply
Old Nov 1, 2023 | 02:50 PM
  #32
savingshound's Avatar
savingshound
Originally Posted by pburger
Awesome cross-reference!! I ordered my last set of refills from Infinitipartsdeals.com in March of 2017. They were $7.34 each, which I didn't think was too bad. Well, after 3.5 years, they're not quite up to the job. When I tried to order replacements, I found out these have been DISCONTINUED from Infiniti. Then I found this thread!! I double-checked the Mitsuba part numbers on my blade refills and they match the ones in the original post.
These are for my 2013 G37 Vert
Driver side -- Honda Part #76622-STK-A02 (Mitsuba 650mm MOB2-S2-105) [Discontinued Infiniti part 28895-1ME5C]
Passenger - Honda Part #76632-SWA-J02 (Mitsuba 425mm MOB2-S2-085) [Discontinued Infiniti part 28895-JK67A]
I ordered these on Amazon, and should have them in about 10 days.
Kudos to the OP Guy Gourdet!!
Hi there,
Just wanted to commend all the folks that contributed to this thread. Saved me a bunch of money as the local Infiniti dealer wanted $23 for the passenger side and $45 for the driver side wiper blades (not inserts)
While the driver side part number (#76622-STK-A02) was a total fit, but the Honda Passenger side Part Numbers (#76632-SWA-J02 & #76632-S73-J01 ) listed by folks on this thread did not work for my 2013 G37x. The base that holds the metal ribs was too thin.
With the help of a friendly Honda Parts guy I was able to find a Mitsuba MOB2-S2-085 (400mm) wiper insert. The Honda Part number is #76632-STK-A02. This insert was a perfect fit. Cost me $7.95
Just thought pass this along.
thanks
2013 Infiniti G37x OEM Replacement wiper inserts from Honda
Base of original wiper and replacement wiper inserts matches perfectly
Savingshound
bpc23
General Tech Questions
Jun 25, 2019 10:29 PM
Idkanymore
Aug 6, 2013 08:44 PM
Formula1
Feb 9, 2009 05:11 PM
Ahujadaddy
Intake and Exhaust
62
May 11, 2008 12:26 AM
