Link to battery replacement how to?
Old Feb 24, 2016 | 05:45 PM
hobbs's Avatar
hobbs
2011 G37 Coupe.
Old Feb 24, 2016 | 06:08 PM
Kris9884's Avatar
Kris9884
Its VERY straight forward.
1) Pop the hood.
2) Release the 2 little tabs on the cover that says "battery" and lift it away.
3) Use the correct size wrench to loosen both the negative/positive terminals.
4) Pull out the battery, it can be heavy.
5) Place the new battery back in the battery tray.
6) Attach the positive/negative terminals to the matching colors (red or black) or symbols ( +/- )
7) Replace the plastic battery cover and clip it into place.
8) Save your radio/seat settings all over again.
Profit.
Old Feb 24, 2016 | 08:18 PM
hobbs's Avatar
hobbs
1) Pop the hood.
Profit.
I thought there were more trim pieces to be removed? Put a new battery in my wife's and my car is jealous and wants a new one too.
Old Feb 24, 2016 | 08:37 PM
There's only one trim piece but it has 5 or 6 clips holding it in. Remove them by popping them up with a flat screwdriver. Also, you will probably need to take the fuse box loose (not remove it) to get more room. It's clipped in, just pull up on it. The nut size on both terminals is 10 mm.
Old Feb 25, 2016 | 06:58 PM
hobbs's Avatar
hobbs
(2) trim pieces. PIA to get out without a handle! The older I get the heaver batteries get.
Old Apr 28, 2016 | 12:28 AM
tite_tite's Avatar
tite_tite
Wow!! the stock battery without handle was a PIA to get out for real!! what technique is everyone using to take it out?
my replacement battery came w/ a handle & if only the stock came w/ a handle. it is already replaced but wonder how everyone took it out besides lifting w/ 2 hands/arms of course.
Old Apr 28, 2016 | 01:44 AM
Try this
Old Apr 28, 2016 | 07:44 AM
G37sGraphite's Avatar
G37sGraphite
I used this (link below) easy, worked perfectly....and you don't need steroids ^^^
Infiniti G37 Battery replacement for all G37 coupes and G37 sedans, including 2007 and 2008 G35 sedan
Old Apr 28, 2016 | 10:14 AM
tite_tite's Avatar
tite_tite
Try this
Lol.. Her-cu-ly Her-cu-ly
Old May 16, 2016 | 03:20 PM
Juelz86g37s2012's Avatar
Juelz86g37s2012
Pop hood
1. Remove all pop out clips
2.lift battery tray
3.10mm socket on battery terminal
4.remove weather strip gromet (cafefully).
5.lift window wipers
6. Remove window wiper cover from windshield
7.10 mm deep socket on battery bracket holder
8. Unhook j hook fitting from battery bracket rear of batter
9. Remove your battery gently/replace all step backwards.
G37bruh
26
Feb 14, 2019 09:16 PM
KAHBOOM
Dec 19, 2016 04:23 PM
nethole
Feb 22, 2016 10:42 AM
Kris9884
Feb 22, 2016 03:06 AM
Rick in NC
Feb 18, 2016 06:22 PM
