How to completely turn off stability control
Old May 18, 2016 | 11:01 PM
ReplicaR's Avatar
ReplicaR
Hey everyone, I'm trying to figure out how to completely turn off stability control. I've recently had a chance to toss around my G37S at the autoX, however any time it would get a little "too sideways", the stability control would step in and kill the power, even though it was turned off. I've heard from many sources that you can't fully turn off stability control without cutting some wires at the YAW sensor and defeating the stability control permanently. I think there has to be another way. Can this be done through tune? Is it possible to keep stability control functional with it on, and fully off with a press of a button?
Old May 20, 2016 | 07:25 PM
smitty37g's Avatar
smitty37g
From what I understand, if you hold the button in (for the asc off) the light comes on... keep the button held down till it turns off (the light). its supposed to be off..
I have not fully tried it, but i have made a couple of circles after doing that.
If im wrong, im sure someone will chime in.
Old May 20, 2016 | 07:28 PM
ReplicaR's Avatar
ReplicaR
I've tried that already, just to eliminate the obvious. All I got in return is stability control being in on position without a way to disable it at all. I had turn the car off and on to regain the control of the stability button.
Old May 20, 2016 | 07:39 PM
smitty37g's Avatar
smitty37g
Welp, I tried... lol.... hopefully some one else chimes in..
Old May 21, 2016 | 02:46 PM
RadioFlyer's Avatar
RadioFlyer
You'd have to install a switch that bypasses the yaw sensor under the console. The plus is that it also prevents ice mode in the abs. So you're fully off with the sensor bypassed.
Old May 21, 2016 | 02:50 PM
ReplicaR's Avatar
ReplicaR
Links to this switch?
Old May 22, 2016 | 01:50 PM
RadioFlyer's Avatar
RadioFlyer
There's a DIY somewhere on this site...
https://www.myg37.com/forums/engine-...bling-vdc.html
Old May 22, 2016 | 05:39 PM
hobbs's Avatar
hobbs
Upcoming post . . .
I bent my car!
Old May 23, 2016 | 09:08 AM
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
https://www.myg37.com/forums/d-i-y-i...n-control.html
jeepbrew
48
Mar 2, 2020 01:55 PM
rhdh104
Apr 24, 2016 12:50 PM
Gfactor_416
Apr 20, 2016 05:26 PM
Jedz123
Apr 20, 2016 12:27 AM
