Torque Wrench Question
Old Apr 2, 2015 | 03:16 AM
vqsmile's Avatar
vqsmile
Originally Posted by tite_tite
Hmmm... so if you getting your tires done at Discount Tire & they use the gun to put the nuts in initially, drop the car & then torque..
if they are using the gun to screw in the nuts over 80lbs, say 100lbs & when the car comes down & they torque it to 80 lbs...it's no point, correct? (since torque wrench won't go back) ??
Like BB said, they're using a torque stick, NOT a simple extension. Torque sticks are totally different.
Old Apr 2, 2015 | 09:50 AM
Lego_Maniac's Avatar
Lego_Maniac
Originally Posted by indowanksta88
Get an extension to use between the torque wrench and lug nuts.
Deep well socket
Old May 29, 2015 | 06:55 PM
tite_tite's Avatar
tite_tite
i understand the torque wrench needs to be calibarated at time but how do you know it is time?
some folks says on a yearly basis but if you don't use it much on that year, how do you know when it is time or is there a way to check before getting it calibarated?
thanks.
Old May 30, 2015 | 09:01 AM
I always haul my tires to the tire shop in the back of my truck, have them mounted, balanced, etc then haul them back home where only my torque wrench ever comes in contact w/ my wheels. I've had too many bad results from taking it to the shops where they just can't resist that air hammer resulting in dings and damage (and over torqued). And this is after I SPECIFICALLY state to please use hand tools on the wheels
rgonz
Sep 11, 2015 04:07 PM
johnadlertech
Sep 11, 2015 02:07 PM
dholmblad
Sep 8, 2015 08:34 AM
xpcgamer
Sep 7, 2015 07:10 PM
