Help Hood stuck, won't pop anymore
Old Jul 20, 2014 | 01:48 AM
masterdukill's Avatar
masterdukill
Angry Hood stuck, won't pop anymore
How do you guys go about trying to fix this? The cable in the cable has no tension at all, so it seems like the latches are maybe still unlocked?
I tried pulling the hood up with finger tips, and the in cabin latch is still doesn't have more tension. Nothing is releasing.
I believe i may have pinched the cable when i reassemble the radiator cover. And more specifically, i think this happened when i stuck on the center screw.
How do you guys go about getting access to this cable? I'm reading the forums, but no one is giving a clear answer.
Do i have to open the side walls for both the passenger & driver side to get access to this cable?
Is it possible to get access if you remove the bottom engine cover?
09 G37 Coupe with Stillen Gen3 intakes
Old Jul 20, 2014 | 02:25 AM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
Go through the driver side wheel well. You should be able to snag the cable if you put the car on jack stands and take off the drivers side wheel.
Old Jul 20, 2014 | 06:16 PM
masterdukill
The driver side was a no go. The cable was too stuck. I had to open the bottom engine bay cover, get a super long screw driver, and poke at the middle part where the wire was being pinched. Luckily enough, i didn't really tighten the area down, so it came loose when i poked hard enough... Lesson learned, when reinstalling the engine bay cover to make sure the cable is not in the way!
delfinparis
Nov 16, 2015 02:26 PM
2K1 6T8
Oct 6, 2015 07:40 PM
Msherburneg37xs
Intake and Exhaust
Sep 30, 2015 06:39 PM
AMCDeac
General Tech Questions
Sep 19, 2015 05:25 AM
