Ester Oil Change Intervals?
Old Sep 8, 2009 | 06:38 PM
Staples's Avatar
Staples
I used the search button, but couldn't find my answer. What is the regular oil change interval when using the Nissan ester oil? I'm having an issue with the knocking/ticking sound coming from the VVEL and I've had the TSB done which fixed the annoying tick, but once I switched to a synthetic blend, the noise came back. I'm thinking about just going with the ester oil and just doing the oil changes myself.
Synthetic blend is good for 7500miles
Full synthetic is good for 10,000 miles
regular dino oil is good for 3750miles.
Where does the ester oil fall under?
Old Sep 8, 2009 | 06:43 PM
Gamedog's Avatar
Gamedog
Sam Rothstein
Should be safe around 5,000 miles IMO.
For the record, I have nothing to back up that statement, but I'm assuming it's ok since you can easily hit 5,000 miles on conventional blend oil nowadays. Better additives/formulas and increased viscosity found in today's conventional blends along with cleaner running engines = longer mileage intervals.
Old Sep 8, 2009 | 06:55 PM
Staples's Avatar
Staples
Thanks Game, I just didn't know if the ester based oil was categorized as basic dino oil. Oil changes could get pretty expensive if it is.
Victory
Sep 28, 2015 10:49 PM
Oh My G 523
14
Sep 26, 2015 07:11 PM
cyberone28
Sep 23, 2015 01:56 PM
ryang37x
Sep 22, 2015 05:33 AM
sharmelan
17
Sep 14, 2015 03:18 PM
