View Poll Results: What brand of oil do you use in your G coupe/sedan?
Motul (300v or 8100)
56
4.06%
German Castrol
44
3.19%
Amsoil
46
3.33%
Redline
49
3.55%
Royal Purple
79
5.72%
Mobil 1 Synthetic
653
47.28%
Pennzoil Platinum
133
9.63%
Valvoline SynPower
31
2.24%
Eneos Synthetic
22
1.59%
Quaker State
0.72%
Lucas Oils (synthetic)
0.43%
Schaeffer Synthetic Oil
0.29%
Nissan Ester Oil
171
12.38%
Conventional 5w30 "dino oil"
77
5.58%
Voters: 1381. You may not vote on this poll
The DEFINITIVE oil thread
Old Jun 28, 2010 | 07:14 PM
  #286
philter25's Avatar
philter25
Originally Posted by MikeySed
11k miles to be exact (if you are referring to me)... I plan to change it in 3750 miles (I don't know what they used for the 15k service, probably ester oil).. I am going to go with Mobile 1 5w30 synthetic. I have used that on an M3, sl55, sl600, and a few z06 corvettes without any issue.
I will do the first change at around 7200 miles.. and send it out and see how it is.. and go from there.
thoughts?
Whenever you change the oil, send it in for a UOA and see how much wear metals are in it. If its all clean after 3750 miles of driving, then go for 7200 with the Mobil 1.
However, since you seem new to the boards, I would advise you to take a look at a few UOAs here on Mobil 1 vs other synthetics. Although Mobil 1 is better than the Ester Oil or any regular oil, there are other synthetics where based on UOAs seem to respond better to this car. Some synthetics with higher ester content, different additive packages and higher flashpoints seem to work better in this engine.
I used Mobil 1 in past vehicles also, but after looking over the UOAs, it seemed there were other synthetics which worked better in this car.
Do a search and decide for yourself, but me, shadowman, mike, jonfromcb, black betty, and a few other posters have been involved in some good oil discussions. Definately make sure you read the Blackstone Labs thread.
I think KLB even posted a few Mobil 1 UOAs and I think he was switching to Pennzoil...... although I could be wrong.
Old Jun 28, 2010 | 09:39 PM
  #287
MikeySed's Avatar
MikeySed
I'll save myself the trouble.. other than mobile 1 what synthetic would you recommend? Penzoil Platinum? Is it typically the same price? or?
or any others would be good too.
thanks for the help
Old Jun 28, 2010 | 09:45 PM
  #288
hispeed-lowdrag's Avatar
hispeed-lowdrag
thanks for the help
try Penzoil ULTRA not platinum. I've seen some good numbers from Ultra, and Royal Purple is also a good one.
Old Jun 28, 2010 | 10:32 PM
  #289
MikeySed's Avatar
MikeySed
5w-30?????
Old Jun 28, 2010 | 10:36 PM
  #290
CougarRed's Avatar
CougarRed
thanks for the help
Here's a few:
Eneos 5W-30 blend - $41.94 for 6 qts at Amazon free shipping
Schaeffers 7000 5W-30 - $5.80/qt + shipping
Pennzoil Platinum 5W-30 - Normally $23 per 5 qt jug at Walmart, but now on sale for $20.50 less $5 instant rebate
Pennzoil Ultra 5W-30 - Normally $28 per 5qt jug at Walmart, but now $23 after $5 instant rebate
Castrol Edge 5W-30 - $26.50 at Walmart. Half off 2nd 5 qt rebate going on brings price to $3.98 per for 10 qts
Castrol Syntec 5W-30 - $25 at Walmart.
RedLine 5W-30 - $109.45 delivered for a case of 12 qts
Others to consider: Motul, German Castrol, Amsoil, Royal Purple, Valvoline SynPower
Old Jun 28, 2010 | 10:42 PM
  #291
hispeed-lowdrag
5w-30?????
Yes. Whatever oil you use it should always be 5-30 regardless of brand
Old Jun 28, 2010 | 11:32 PM
  #292
MikeySed's Avatar
MikeySed
Castrol Edge 5W-30 - $26.50 at Walmart. Half off 2nd 5 qt rebate going on.
thanks for that... so if I go with the pennz. ultra.. we need 6 qrts in order to fill up the g37 right.. well 5 and a 1/4.. so would I buy the jug and then just buy 1 quart separate?
Old Jun 28, 2010 | 11:43 PM
  #293
CougarRed's Avatar
CougarRed
Sure. It technically holds 5 and 1/8. Fill it up with 5 qt jug, check the dipstick, see if it needs more.
Old Jun 29, 2010 | 11:48 AM
  #294
philter25's Avatar
philter25
^ I echo what CougarRed posted.
VOA's for comparison: I added a few to cougarred's list
https://www.myg37.com/forums/engine-...-analyses.html
My thoughts on a few:
Eneos: BB and UCLABruin in their thread posted a few good UOA's with Eneos. It looks promising. UCLA bruin is sending in a sample for a VOA and a UOA, and pending that outcome, that might be my next oil.
Ultra: Its relatively new, but the specs look good. I havent seen a UOA on it from anyone on here yet, but considering its specs and people have had good results with Platinum, its a good choice.
Platinum: Reliable, seems many people on here use it with good results.
Mobil 1: Mixed results. I think a lot of the people who choose it have gone to it because its been their go-to oil in past cars. I used it in my past cars also and if I didnt know any better, I probably would have jumped on it. Its a mixed bag of results. KLB had mobil 1 in for awhile and switched to Ultra I believe, so Im looking forward to his UOA to see if his wear metals decreased with Ultra.
Redline: Costs a ton, but check out the additives in it. My car only had 8k miles on it after 2 oil changes with the Nissan Ester Oil and since it was still in the break in period, I wanted to switch to a synthetic that had a similar additive package as the Nissan Ester Oil. Check out the VOAs, Redline IMO was the closest to the Nissan Ester Oil and Redline has a good amount of ester in it. So to finish break-in for my car, Im going with Redline. I just put in my first 5 quarts at 8k, will probably change the oil again at 14k, and at my 20k oil change Im hoping to switch to Eneos or Ultra or a cheaper synthetic that has a few good UOA's pop up. However, due to Redlines additive package, it has not been API certified.
Amsoil: See Redline about API certification. And I posted some good info on why Redline and Amsoil dont want to be certified because they dont want to dilute their additive package.
German Castrol (Syntec): Is a cult oil for some guys at BITOG. Looks great on UOAs and for the price, its money.
Schaeffers 7000: Good VOA's, good additive packages, but since its not mainstream, not many UOAs of it.
Motul 300V: Holy moly! Other than Redline and Schaeffers, the only oil to have a high moly content like the Nissan Ester oil.
I think I'd use any of these before Mobil 1 in this engine.
If you dont like spending 50 bucks on an oil change for Redline or 42 for Eneos, or 35-40 for Schaeffers 7000, then Ultra for 23 would be a good choice.
Although since you said you have 3750 miles to go before your Oil change, you might be able to see a few UOA's for Ultra or UCLA Bruins VOA and UOA for Eneos come back in a week or two. And all the people who put in Ultra over the past few months are coming up due for oil changes so hopefully we can see some UOAs on Ultra.
Those UOAs and VOA might be pretty informational, so I'd put my decision on hold if possible.
Old Jun 29, 2010 | 01:08 PM
  #295
CougarRed's Avatar
CougarRed
Here's an UOA from an Audi 1.8 Turbo, an engine notoriously hard on oil.
The December 2009 oil was German Castrol 0W-30. The January 2010 oil was Castrol Edge 5W-30. Despite different additive packages, note the wear metals are nearly identical. German Castrol remained more viscous, but the thinner Edge was still in grade and and the driver reported 2 MPG better gas mileage with Edge.
After 5K miles, both had plenty of TBN left for a 7500 interval. GC looks like it could go 10K in this Audi.
When not on sale, GC is more expensive than Edge but less expensive than Eneos.
In the future, I plan on running several 4K mile UOAs in my car to see which oil looks best for a 7K run later. I'll be testing
Eneos
Syntec Blend
Platinum
Schaeffers 7000
Ultra
Q Horsepower
Edge
Old Jun 29, 2010 | 06:37 PM
  #296
xyz's Avatar
xyz
hmm . . . the german castrol mentioned above and previously is 0w-30, but has had good results. Should we not use them?
Old Jun 29, 2010 | 08:16 PM
  #297
philter25's Avatar
philter25
I think the 0w30 GC is fine. Depending on who you talk to on BITOG, there are some guys who put in 5w30 in the summer, and then 0w30 in the winter.
0w30 is a bit thinner at startup, and then a tad thicker at operating temperatures compared to 5w30.
Old Jul 1, 2010 | 09:17 AM
  #298
KLB's Avatar
KLB
I'll be changing my oil this weekend and sending in my Ultra for analysis next week. I'm at a little over 6K miles on it. We'll see in a week or so how it held up.
I'll be putting in Ultra again this time as well. The results of the UOA will determine whether I stick with it after that.
Old Jul 1, 2010 | 09:38 AM
  #299
MikeySed's Avatar
MikeySed
look forward to it.. I will be switching to that after my oil change thats in the car I bought in another 3100 miles
Old Jul 1, 2010 | 09:42 AM
  #300
CougarRed's Avatar
CougarRed
Awesome!! If you don't mind, please ask for a TBN analysis too.
