First Oil Change
Old Mar 31, 2009 | 05:40 AM
kkokko's Avatar
kkokko
First Oil Change
I got my G37 in Early October 2008, When should I go bring it in to change the oil? The dealer in Canada is giving me a different first oil change date, compared to what it says in the g37 USA Manual...
I don't mind changing it earlier, as it's been almost 7 months with regular driving and about 2500miles on it... What do you guys think?
It must have been sitting in the dealer lot for quite sometime before as well....
Thanks!
Old Mar 31, 2009 | 06:00 AM
vukhey's Avatar
vukhey
dealership recommendation was 3750 miles for me. so i would wait until you reach that point because if youre planning on changing your oil there, its almost 100 for their "special" ester oil.
Old Mar 31, 2009 | 06:02 AM
kkokko's Avatar
kkokko
isnt it 6months or 3750? so does that mean mine is due since it hit 6months alrdy?
Old Mar 31, 2009 | 06:38 AM
STOOF's Avatar
STOOF
7 months on regular oil? You should change it now.
If you switch to a good synthetic you can easily change it once a year.
Old Mar 31, 2009 | 06:53 AM
kkokko's Avatar
kkokko
hm.. should i change it to the expensive ester oil as recommended?
The Canada dealer says, they upped the first oil change and it's unnecessary to bring my car in yet..
Old Mar 31, 2009 | 07:37 AM
Blackjack's Avatar
Blackjack
I recommend at change at break-in... 1250, then another one at the normal maintenance intervals of 3750. I use only synthetic ester based (Motul) at each of those 3750 intervals.
Old Mar 31, 2009 | 07:43 AM
kkokko's Avatar
kkokko
so since my base model g37, was probably sitting on the dealer lot for a year... and 7 months of driving with 2500miles I should change my asap?
Old Mar 31, 2009 | 10:54 AM
Sitting on a lot has no adverse effect on your oil. I also strongly disagree that it's necessary to change your oil at "break in" mileage as suggested by Blackjack, that is just wasting your money. The manufacturer nor dealer says this is required or even suggested. Just take it in at the 3750 like the manufacturer suggests. Unless your car has been run really hard, has been in extremely hot conditions, or has been in an environment with lots of sand or dust, it's not necessary to change your oil before recommended change intervals.
There's no way in hell your car was on any lot for a year dude. Look at the plate that tells you the manufacturing date to bear this out.
What did your dealership say regarding the mileage interval for your initial oil change that's different from what the manual says? This is interesting and I haven't heard of a dealership saying to extend the first oil change interval mileage before.
Also, here is a good resource on the subject with people more knowledgeable that you'll find in this forum, including me. It may be a lot of reading to sift through the forums, but you will be educated and stop freaking out about oil changes and get some solid information.
BITOG
Old Mar 31, 2009 | 11:02 AM
2009G37's Avatar
2009G37
Having said that though, I thought you were supposed to change at 6mo or 3750, whichever came first. I was told that "old oil" is bad, even if your car hasn't been driven lots.
It doesn't totally make sense to me though....I mean, if a car has been on the lot for 6 months, the oil is 6 months old, but it hasn't been driven. Should it be changed?
Old Mar 31, 2009 | 11:20 AM
Blackjack's Avatar
Blackjack
I think you misunderstood... It's my recommendation. It's absolutely not necessary. And if you change your oil yourself, it's really not that much of an expense... $30-40. It's simply something that I've done on all my cars that I'll continue to do.
Old Mar 31, 2009 | 11:55 AM
What makes it any worse simply because it's 6 months older than before? Is oil that's been sitting on the shelf in a warehouse or a store for 6 months no good anymore? Of course not!
Here's my logic: If the car isn't driven, what has happened to the oil in 6 months sitting inside your engine to make it any less effective at lubrication or any more contaminated than it was the day you put it in? Contamination? Break down? How???
Th ONLY reason to change oil is if it is contaminated with particulates or foreign material or if it has chemically changed so that it's not effective at lubricating your engine. Time by itself does neither of those.
If my car had sat mostly undriven for6 months, I might change my filter only, but not the oil. It's a waste IMO. Some people like Ballin' Blackjack said may do it for their own personal peace of mind which you can't put a price tag on, but I don't have that kind of money to blow. I consider spending $22.50 at Blackstone Labs a better investment. That kind of peace of mind has science behind it and can help me to keep the money in my pocket for an extra 3K, 5K, or more depending on my individiual driving circumstances.
$30 - $40 and 20 minutes of someone's time might be a small price for him to pay to have confidence that their investment is well protected. That's cool and to each his own; I used to be that guy who changed every 3K with full synthetic. I got a lot of miles out of those engines without a doubt.
Nowadays I spend oil maintenance money more wisely and I blow my money on more beer!
Old Mar 31, 2009 | 11:56 AM
kingkong79's Avatar
kingkong79
Lol, my 08 G37 was sitting on the lot for at least a year. Purchased end of Feb 09 and date of manufacture was either 10/07 or 12/07, I forgot. Since I am leasing, I didn't care too much. Now if I was buying outright, I would have given them hell. Only had 33 miles though (7 from the initial Infiniti Test Drive) and I guess the rest to transfer from the original dealer.
Old Apr 20, 2009 | 04:05 AM
kkokko's Avatar
kkokko
hm.. I'm looking at the oil change interval in the 2009 maintenance pdf http://www.infinitiusa.com/pdf/techp...7-Coupe-v2.pdf
and it's saying 3 month or 3750 miles.. what? 3 months???
Old Apr 20, 2009 | 06:55 AM
todd92's Avatar
todd92
The interval is 7500 miles. Any synthetic will last longer than that. Get rid of the factory oil at 3750 miles, switch to the synthetic of your choice. Stay away from the dealer and the Nissan Ester oil.
Victory
Sep 28, 2015 10:49 PM
Oh My G 523
14
Sep 26, 2015 07:11 PM
cyberone28
Sep 23, 2015 01:56 PM
ryang37x
Sep 22, 2015 05:33 AM
sharmelan
17
Sep 14, 2015 03:18 PM
