Horn Sound Issue
Old Mar 26, 2024 | 07:56 PM
Infiniti7's Avatar
Infiniti7
Horn Sound Issue
I own a 2009 G37x and I just had some work done on the car including installing a new engine mount. I got the car back and the horn for some reason seems dumbed down especially when I lock the car. Doesn't seem to have the same sounding kick it's always had. Any thoughts on what could have happened?
Old Mar 27, 2024 | 10:33 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Were the horns disconnected and, if so, did they reconnect both of them?
Could be a bad ground, bad relays, cut wire etc. I'd at least check above first then go from there. Strong chance they were disconnected to make way for the work you had done.
Old Mar 27, 2024 | 10:52 AM
Infiniti7's Avatar
Infiniti7
With not knowing much right now what's the easiest way to go about checking without taking things apart?
Old Mar 27, 2024 | 11:40 AM
ILM-NC G37S
Open the hood and start digging for the two horns. Make sure both are plugged in. This is from the Coupe but should be the same/ similar for the sedan:
Old Mar 27, 2024 | 12:11 PM
Infiniti7's Avatar
Infiniti7
Ok I'll give it a try. It's just odd because I'm getting different kind of alerts as well on the dash that I've never seen before. The temperature logo seems different and what looks like a horn setting has popped up if I'm reading it right
Old Mar 27, 2024 | 12:36 PM
ILM-NC G37S
Well now you are talking about an entirely different set of symptoms. Elaborate on what the car is telling you/ post pics of idiot lights, messages, etc.
Old Mar 27, 2024 | 06:30 PM
Infiniti7's Avatar
Infiniti7
yes i know I is two different things but I just didn't know if this may have something to do with it as well. Maybe not though. Never seen this before on my dash
Old Mar 27, 2024 | 07:43 PM
ILM-NC G37S
Ok, that is the "Time to Rest" alert. This can be set by drivers who are on long road trips to remind them that it is time to take break. I do not think 99% of owners even know it is there and probably 99.9% never used it.
How this got set in the first place is a mystery. Seems maybe someone has been "monkeying" with the cluster/ settings.
This should have zero effect on your horn issue.
Old Mar 29, 2024 | 10:29 AM
Infiniti7's Avatar
Infiniti7
My horn has seem to come back to full strength as of last night after driving the car around over the last couple days since getting it back from the shop. I will have them take a look just to double check but I do know that the battery is a little weak from the car previously sitting for a while before having it fixed. Could the battery have anything to do with it?
Also I took csre of the alerts i think they were messing aroumd with the computers after an oil change
Old Mar 29, 2024 | 12:18 PM
ILM-NC G37S
Originally Posted by Infiniti7
...Could the battery have anything to do with it?
Possible, but doubtful. The horn still should have sounded fully with the engine running. Engine off, if the battery was weak to the point it could not fully sound the horn then it never would have cranked the engine. But, who knows for sure... your horn works now and that is all that matters at this point.
Thanks for the update.
Old Mar 29, 2024 | 08:11 PM
Infiniti7's Avatar
Infiniti7
Ya I just wonder if it has to do with a connection or some sort still
Kenny Xie
Jul 30, 2014 08:45 PM
Creepers
Feb 12, 2012 09:21 PM
Gunit37
General Tech Questions
Aug 13, 2011 03:23 AM
08g37
Jan 25, 2009 07:11 AM
patmsb1
Feb 28, 2008 05:38 PM
