Weird noise shortly after braking (2012 sedan)
Old Oct 26, 2023 | 01:58 AM
Madara's Avatar
Madara
The other day while in a drive thru I heard a weird grinding/squeak/scraping sound coming from the passenger side when I would let off the brake. A few days later im still hearing it, it seems like it only makes the noise when I let off the break or when im going under 10mph. I thought it could be some dust or something trapped in there so I tried a few hard stops to see if thatd do anything but to no avail. Its not a constant sound but sounds like something is scratching when the wheel makes a rotation.
Pads are fine, rotors arent the best but I wouldnt think its them, I just replaced the bearing hub assembly a few months ago, I had a bent brake dust shield on that side so Ill see if its that again.
Just want a few ideas before I take a look at it this weekend, any suggestions are appreciated ;D
Old Oct 26, 2023 | 07:57 PM
mummy2's Avatar
mummy2
Sounds like a seized caliper.
Old Oct 26, 2023 | 10:08 PM
beefychicken's Avatar
beefychicken
Concur with @mummy2
But the situation could have different ramifications dependng on the type of brakes. Is it the standard brake setup or the Akeebono (big brakes)?
Old Oct 26, 2023 | 10:16 PM
Epiphany's Avatar
Epiphany
Most likely dragging pad, probably the inside one on the rear. Mine did that a couple years ago. New caliper and pads/rotors were needed for mine.
Old Oct 26, 2023 | 10:25 PM
Madara's Avatar
Madara
I see, thank you for the reply. I always thought when you have a seized caliper the car pulls when breaking and you can smell something burning. Am I just at the beginning of seized caliper stage or are those symptoms not always going to happen? Would just buying a new caliper be better than trying to repair this one?
Old Oct 26, 2023 | 10:26 PM
Madara's Avatar
Madara
Standard
Old Oct 26, 2023 | 10:28 PM
Madara's Avatar
Madara
Ahh that would suck, did you notice anything else when you had a dragging pad?
Old Oct 26, 2023 | 11:10 PM
beefychicken
You could try pulling the caliper and cleaning and greasing the slides.
Old Oct 27, 2023 | 06:02 AM
Madara's Avatar
Madara
Will do. Thanks for the suggestion
Old Oct 27, 2023 | 10:33 PM
Epiphany's Avatar
Epiphany
The scraping/grinding noise, and since my pads were getting low anyway the inside pad was throwing a lot of brake dust into my wheel. Cleaning and lubing things might fix it if you're lucky.
Old Oct 28, 2023 | 04:46 AM
Madara's Avatar
Madara
Sweet ill try it, thanks for the advice
Old Nov 8, 2023 | 12:35 AM
mummy2's Avatar
mummy2
So what was it?
Andrew21kg
Apr 5, 2021 04:54 PM
BobbyKasoca
Apr 30, 2018 11:41 PM
m0nkey
General Tech Questions
Jan 14, 2015 10:35 PM
Mike888
Nov 13, 2013 01:08 PM
teh slab
Jan 22, 2008 03:01 PM
