Akebono BBK on X coupe?
Old Sep 22, 2013 | 09:57 AM
Ryno23's Avatar
Ryno23
Hey guys quick question. I've got an 09 G37X coupe and it's just about time for new brakes so I really would like to just spend the extra money and upgrade to the Akebono BBK. I do know that it will clear my CV7s so I'm not worried about that but will they clear my stock wheels, just Incase I would ever have to go back? Also has anyone does the Akebono BBK on an X coupe? I would assume the it would be the same setup for a good fit but I'm not positive and I just want to clear everything up before I buy them. This is the kit I'm planning to order Incase anyone needs to see it. Thanks guys!
Akebono Infiniti Front and Rear 14 Inch Big Brake Kit w/ Stoptech or Centric w/ Zinc Rotors, 07-08 G35 Sedan, 09+ G37 Sedan, and 08+ G37 Coupe - performance parts
Old Sep 22, 2013 | 10:32 AM
There's been quite a few X installs so the install itself will be fine. As far as clearing the stock 18" wheels, not sure. Here's a front & rear template that you can use for your stock wheels, I used a cardboard cereal box for the backing and it worked fine. Keep in mind you'll need a spare tire from an S model to clear the brakes as well
http://www.conceptzperformance.com/i...nttemplate.pdf
http://www.conceptzperformance.com/i...artemplate.pdf
Here's the Nissan version (they usually sell for more, not sure why) if you like the Gunmetal finish better.
Nissan Akebono BBK Big Brake Kit Complete Upgrade - Nissan 350Z 370Z
Old Sep 24, 2013 | 12:07 AM
Ryno23's Avatar
Ryno23
^^Ok great thanks man! If anyone else has anymore input, feel free!
Old Sep 24, 2013 | 10:00 AM
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
Pretty sure the stock 18's will not clear without spacers.
Old Sep 28, 2013 | 08:28 AM
thisISit's Avatar
thisISit
I have an '11 XS...awd and bbk
Old Sep 29, 2013 | 02:56 PM
Ryno23's Avatar
Ryno23
Great thanks for the input guys!...thisisit what are the offsets and sizes of your wheels?
Old Nov 5, 2013 | 05:34 AM
mark1478's Avatar
mark1478
did you do it Ryno? debating on this as well
Old Nov 6, 2013 | 08:20 AM
Ryno23's Avatar
Ryno23
Not yet mark. There's a few other things I wanted to do before this. Maybe by next season I will. Do you plan on doing it?
Old Nov 17, 2013 | 08:51 PM
footlianjia's Avatar
footlianjia
i want to ask also,I wanted to do before this. Maybe by next season I will. Do you plan on doing it?thanks
Old Nov 17, 2013 | 09:19 PM
mark1478's Avatar
mark1478
I actually just started. found a great deal on akebono calipers and steel lines. i had it shipped to Chicago for custom powdercoating and decals. all I need now are the rotors, in debate if I should just buy new or wait for a good used set to pop up
Old Nov 27, 2013 | 07:48 AM
RexHavoc's Avatar
RexHavoc
I'm running them on an x sedan with no issues other than rims. I had to use spacers to clear a set of stock 18s. I did it sooner than I originally planned or the rims wouldn't have been an issue since I'm going to 19s. It's going to make it more difficult to get them painted etc but the deal I got was too good to pass up.
Old Nov 29, 2013 | 10:03 PM
Ryno23's Avatar
Ryno23
Thanks for all the input guys! Im hoping by summer to be able to pull the trigger on the bbk!
Old Dec 19, 2013 | 01:25 PM
TheLocNar's Avatar
TheLocNar
The S wheels will clear the calipers. If you have the non-S wheels, you'll need spacers, or other wheels. And yes, don't forget about the spare tire too.
Old Dec 21, 2013 | 10:31 PM
Ryno23's Avatar
Ryno23
Great thanks!
Old Dec 29, 2013 | 10:05 PM
Yan141's Avatar
Yan141
So BBK kit are bolt on X with no modification required? Im planning doing this on X sedan in couple of months. I should be ok with my 20" wheels.
