Steering rack leak
Old Jun 16, 2022 | 09:33 AM
G37sPhoton's Avatar
G37sPhoton
Steering rack leak
Was getting an oil change recently and tech mentioned leak but wondering if my PS pump fluid is right where its been since my last turkey baster drain and fill, is this something just best left alone? Or will this get worse and should address now etc?
Old Jun 16, 2022 | 11:03 AM
BULL's Avatar
BULL
Moderador
Very common leak. this is the rack "play" adjuster. It's a flat nut with a threaded bolt and a moon typed spacer that pushes on the rod of the rack. because it relies on clamping force to seal many times it's impossible to seal. I believe Nissan uses a type of grease in glob form for this area that over years and fluid changes it deteriorates and starts leaking.
Other than replacing the rack the only thing you can do is to clean this area extremely well with carburetor cleaner then dry as soon as possible and coat the exterior with a nice glob of strong RTV or even epoxy.
Taking of this part and coating the threads might result in a too tight or too loose of a rack which is why I dont suggest you do it. it will be extremely difficult to see any fluid drop since its not dropping leak but more of a "moisting" one.
Overall clean it up and monitor it over time, once you start noticing levels dropping you can try the trick above.
Old Jun 16, 2022 | 07:23 PM
G37sPhoton's Avatar
G37sPhoton
[QUOTE=BULL;[url=tel:4312044]4312044[/url]]Very common leak. this is the rack "play" adjuster. It's a flat nut with a threaded bolt and a moon typed spacer that pushes on the rod of the rack. because it relies on clamping force to seal many times it's impossible to seal. I believe Nissan uses a type of grease in glob form for this area that over years and fluid changes it deteriorates and starts leaking.
Thanks Bull, been reading all over and you are dead on... you are a frigging wealth of info Sir! Have gone over your build thread a few times and learned a lot, again much appreciated... still in Miami? My daughter may transfer to University for her medical degree and if so, ill owe you a brew of your choice(attorney quick talking disclaimer-brew of your choice under 100) 😬
Old Jul 9, 2022 | 03:45 PM
AnotherVQ's Avatar
AnotherVQ
I'm assuming you said carb cleaner because people may have this laying around. Since I don't, do you have other reccomendations for what to clean it with? CRC Throttle Body Cleaner? Meguir's Quick Detailer? Degreaser spray? Anything else?
Old Jul 12, 2022 | 02:43 PM
BULL's Avatar
BULL
Moderador
You'll need a type of hard core cleaner like TB cleaner/Carb/Brake cleaner. The reason why is that you need as much cleaning power as possible coming from a thin type cleaner, the reason is that it needs to get as deep in the threads as possible and dry as quickly as possible so that you can glob the entire area with silicone/RTV as quick as possible to prevent fluid from contaminating the thread surfaces. By doing so you're prepping the thread surface to accept the silicone/rtv and grab onto it. If done correctly you should end up with a "sealed" cap.
A sealed cap wont leak.
P.S. Flex seal can work really good as well.
Old Jul 12, 2022 | 02:45 PM
AnotherVQ's Avatar
AnotherVQ
Or maybe slap some flex tape on it 🤣
I'll use tb cleaner then. Ty.
Old Jul 13, 2022 | 11:09 AM
rotarymike's Avatar
rotarymike
Moderator in Moderation
I think this is a British oil seal. IE, as long as it's seeping you're not out of oil. If it dries out, worry.
Old Jul 13, 2022 | 01:45 PM
Selym's Avatar
Selym
Is it dripping on the ground? Is the fluid level dropping? If not, I'd consider that seepage more so than an actual leak, and not worry about it.
Old Jul 15, 2022 | 11:18 AM
BULL's Avatar
BULL
Moderador
By utilizing the technique I mentioned you're able to slow this seepage down even more rendering it out of the maintenance list and putting it in the back burner.
This leak can depending on how fast, start saturating your Left boot in oil and start caking that area as well.
The method listed shouldn't take that much time, it can even be done on your next oil change.
Old Jul 19, 2022 | 03:11 PM
G37sPhoton's Avatar
G37sPhoton
Originally Posted by BULL;[url=tel:4312920
4312920[/url]]You'll need a type of hard core cleaner like TB cleaner/Carb/Brake cleaner. The reason why is that you need as much cleaning power as possible coming from a thin type cleaner, the reason is that it needs to get as deep in the threads as possible and dry as quickly as possible so that you can glob the entire area with silicone/RTV as quick as possible to prevent fluid from contaminating the thread surfaces. By doing so you're prepping the thread surface to accept the silicone/rtv and grab onto it. If done correctly you should end up with a "sealed" cap.
for sure going to do this!!!
LiTo
May 31, 2023 03:22 PM
Scottfreidel
Aug 8, 2020 11:23 AM
Vanilla_Rice
Oct 21, 2019 04:08 PM
Curtis Roberts
21
Jul 10, 2018 11:06 PM
lmt37
Jul 20, 2017 03:49 PM
