Wheel fitment/mounting issue help?
Old Oct 27, 2021 | 04:19 PM
  #31
spoolin03's Avatar
spoolin03
Originally Posted by stealthee
Just because a wheel has more offset does not mean it needs longer wheel studs. The offset has nothing to do with how far the lug studs stick through, unless you are using spacers to make them stick out more. Factory wheels on my Lancer are 18x7 with a 46 offset. Wheels on the car now are 18x8 with a 35 offset. They stick out considerably more than the factory wheels, almost a full inch, but the lug stud protrusion didn't change any.
I think some wheels get those offsets by adding more metal where it contacts the studs, no?
Old Oct 27, 2021 | 04:25 PM
  #32
Birdie's Avatar
Birdie
No. Offset is how far the wheel mounts from the center of the wheel itself .
Old Oct 27, 2021 | 08:51 PM
  #33
Ponyryd's Avatar
Ponyryd
Originally Posted by Birdie
Looks like your lug nuts are the problem. According to the image above looks like the lug Is to big and not seating all the way .If the lug is stopping where all that scraping is at the lug, I can see how it may only be catching about three treads or turns should i say.the lugs should be able to seat all the way in and only use the base to aligned the wheel properly .(those do look oem are you sure they are tuner style,they should look a lot skinnier?).
I see no issue with the lugs, if you look at the seat it looks just fine…maybe you’re seeing the paint not worn off on the right lug and mistaking that for poor fitment? Well the lugs are painted/powdercoated/andonized, and the wheel is painted or powdercoated as well, so it won’t necessarily be worn off.
01collinp
Aug 19, 2020 02:15 PM
VelisG37s
Nov 7, 2015 12:41 AM
G37Xtreme
Jan 5, 2015 08:30 AM
breftayka
Apr 1, 2011 11:35 PM
TJHG37S
Southern California
16
Jun 10, 2009 10:43 AM
