Broken sensor behind oil filter with no check engine light
Old Sep 9, 2020 | 10:35 PM
pkolla's Avatar
pkolla
Hi All,
I have a 2012 infiniti g37x. I recently changed front differential and in the process broke a wire to the sensor to the right of differential and behind oil filter.
I do see 2 sensors. The broken one is to the left closer to differential. There is no check engine light and car starts fine. I thought it was oil temperature absurd and researched online but all of them show 2 pins to the connector but the broken one on the car shows one pin plug. Please let me know which sensor I have broken?
Old Sep 10, 2020 | 07:07 AM
SonicVQ's Avatar
SonicVQ
That is the oil pressure switch. They are not expensive and easy to replace.
Old Sep 10, 2020 | 09:40 AM
pkolla's Avatar
pkolla
How about the one next to it, which is connected?
Old Sep 10, 2020 | 09:42 AM
SonicVQ's Avatar
SonicVQ
engine oil temp
Old Sep 10, 2020 | 09:53 AM
pkolla's Avatar
pkolla
engine oil temp
Thanks!
Curious why the check engine light didn't show up? I have been running the car with it broken for more than a month.
Old Sep 11, 2020 | 12:27 PM
antirice's Avatar
antirice
The dummy oil pressure sensor will not trigger the CEL even if it's disconnected.
Old Sep 11, 2020 | 04:48 PM
SonicVQ's Avatar
SonicVQ
Originally Posted by pkolla
Thanks!
The check engine light is only for emission related problems. Low oil pressure is not an emission problem.
The oil pressure switch only purpose is to turn on the "low oil pressure light" on the dash.
I have had mine disconnected since January to make room for my oil pressure sensor.
Old Sep 12, 2020 | 12:11 AM
pkolla's Avatar
pkolla
Funny part is not even "low oil pressure light" show on dash and I am the only owner of the vehicle, so should be brand new from infiniti.
Old Sep 12, 2020 | 07:33 AM
SonicVQ's Avatar
SonicVQ
The low oil pressure switch works by connecting the the signal wire to ground, when the oil pressure is below about 4 psi. So, when it is disconnected, you will never see the low oil pressure warning.
BUT if you are low on oil pressure sensor, you will have an intake cam timing error like a P0011.
Old Oct 11, 2022 | 04:49 PM
adrianbf's Avatar
adrianbf
I have to replace mine. Do you know if I HAVE to get OEM or will aftermarket get the job done?
Old Oct 11, 2022 | 04:59 PM
SonicVQ's Avatar
SonicVQ
Aftermarket is fine... it is just a simple switch
01collinp
Jan 24, 2020 12:23 PM
happy12345
Dec 15, 2018 09:45 PM
Dan G37
May 4, 2018 09:23 PM
tdoug
May 23, 2015 11:13 AM
