What vehicle will be a worthy replacement for your sedan when it is time?
Years ago I had a Mazda 6s hatchback. Loved the flexibility the hatch provided.
I guess I need to do my homework too. The whole 4 door "coupe" thing seems kinda like "alternative facts"
edit: I guess if you scroll down, even wiki says there is a "variation" of coupes that have 4 doors and a "coupe like roofline". IDK, that seems vague. Like, what defines a "couple like roofline" is in the eye of the beholder, or the market department
Yeah, and all the other German manufacturers piled on. Marketing lingo aside, I see it as a sedan, or a hatchback. And it does bridge some of the difference in trunk space between a car and a CUV. With the rear seats folded down and the parcel shelf removed, it's a huge space.
https://en.wikipedia.org/wiki/Coupe
Please don't ever do legitimate research using Wikipedia as a source, lol. Coupe and sedan are actually defined by interior space. Those big S Class "coupes" by Benz for example are actually sedans. The Ferrari 612 Scaglietti, Mercedes CL-Class, Chevy Monte Carlo, and surprisingly, the Mazda RX-8 are also sedans.
I did a lot of searching on the bentley forums, seems the twin turbo w12 is a bulletproof engine. Electrical issues seem to be the main concern and a lot of those are apparently caused by water getting in by bad seals. Seems i could use some silicone lube or something to keep that issue away. Not a whole lot of mods you can do with them either, exhaust, intake filters, tune, wheels, and shocks. A kind of a plus i wouldn't be constantly buying aftermarket parts like i am with my g37. Its unique around here too, maybe seen 2 in the past 10 years, a red continental gt and a silver flying spur.
The big question I had was how the turbo V6 and 8 speed auto compared to the 2.0T and 7 speed DSG. This is an apples to oranges comparison, since our A4 is piggyback tuned, and probably makes similar torque to the stock V6, and at light throttle, I didn't feel any real difference. Once past 4500 rpm or so, the V6 definitely makes more power, and sounds fantastic in comparison. Oddly enough, I thought the DSG felt sharper, shifting quicker and responding faster to the paddles. The 8 speed felt smoother at low speeds in traffic shifting between 1-2-1 etc.
Both our A4 and the S5 I drove were Premium Plus trims, so the only real difference is the seats. The diamond pattern stitched seats are gorgeous in Magma Red, but they didn't feel much more supportive. Unfortunately, if you want ventilated seats, you have to downgrade to the optional in the a A4 sport seats. Fortunately, the standard seats have a massage function, which I thought would be a gimmick, but were actually pretty nice. Pros and Cons to each. Ventilated seats would be nice on hot days when the car is sitting outside, while I think massaging seats would be nice on a long trip. I generally make small adjustments to my seating position anyway so my back doesn't tighten up and I think this would accomplish the same thing, probably even more so.
I am not surprised you like the DSG transmission better. The regular 8AT was the one real disappointment for me in that car. It is very smooth and quiet, but it is also very boring and I found myself constantly speeding because it was hard to get a good judge on speed with that A/T compared to a DSG since you have one more layer between you and actual involvement in the car. I'm not sure if your wife would be a fan, but E85 tunes on that car are bonkers. Over 600 lb/ft. of torque!?!
I am sure you already noticed this, but most of the additional space in the S5 is produced with additional height up to the back window which is not terribly useable space and also means you need to block the rear window to take full advantage. However, the big advantage is having nearly suv-like space for hauling larger items with the rear seats folded down.
Speaking of seats the massaging part was a surprisingly good feature. You can pick 3 different types of massage and I believe even choose different intensities. They also made some of them with suede inserts in the seats which is my preference since they are not super hot in the summer and ice cold in the winter like leather. They are just harder to find because the full leather is actually considered an upgrade. One S5 hack is that if you want the heated steering wheel on a used one you can easily tell in pictures because the steering wheel will be fully round instead of a flat bottom. Another hack is looking for the red painted brake calipers in pictures as this will give you the sport package with the adaptive dampers and more importantly the active rear differential. It handles extremely well with this package and the right tires.
They had a couple A5 sportbacks that didn't have the full leather and it looked like cloth but I didn't pay that close of attention. You'd probably have to find a base model to get cloth and no heated wheel, since the wheel is included in Premium Plus and Prestige Packages, which is too bad, I'd prefer the flat bottom wheel. All the S5s were loaded up with the higher trims packages, the ring puddle lights, and the "sport resonator" etc. Why not, right?
That's right, the A5 might be black cloth inserts if I remember right, but those are nice too. The suede inserts on S4/S5 are a little bit lighter gray with lighter stitching. Really nice looking. I'm told the sport resonator sounds nice and I think it even sounds decent under load without it. All the guys at Audi told me to get it when I was looking at S4's.
Well the good news is that if you like Magma, there always seem to be a few more S5's with those seats on the used market than the suede inserts. If you are considering new then you don't need to worry at all.
^^^^ SO MUCH THIS ^^^^
I did my final paper in MBA level Marketing on how marketing as practiced today is the root of all evil. Prof didn't like that. Dean of the uni did though so :shrug:
Perception is often reality anymore. Infiniti should be an MBA use case on **** poor marketing and squandered opportunity.
The Nissan Titan is another great example of **** poor marketing. Excellent truck that everyone who owns one seems to love, but completely invisible in the marketplace.
