Old Jun 21, 2023 | 06:30 PM
  #9451
Selym's Avatar
Selym
short rear gears
Outside of adding forced induction, this is probably the most palpable mod you can make to a daily driver.
Old Jun 21, 2023 | 07:27 PM
  #9452
Josh South's Avatar
Josh South
Everything he just said.
I suppose it depends how you use the car. If you live at the quarter mile, then sure, go for every ounce of peak HP you can squeeze out of it. Or if your hobby is all about numbers and bragging right, then shoot for that moon. But if you're driving the car, you know... like a normal person in traffic with other cars, then you want mid-range gains, because that's where you live.
I've always thought this was a strange argument. So much that I never bothered to get my car on the dyno. My completely unmeasured opinion is that the short rear gears, taut suspension and sticky tires all combine to give me low-end response. The intake & exhaust mods were initially providing top-end gains, until the tune cleaned things up and moved those gains into the mid-range.
IDK... not an engineer, but that's always been my thoughts on the matter. We live under the curve, not on it.
I agree, I was planning on keeping to stock airboxes with drop ins… I just loved how the engine bay looked with long tube intakes. I got my afe intakes used for a steal but always hated how they necked down. So I changed that 😎 and my tuner said they would tune for the bigger diameter, so why not. Now I just need to make it look pretty again. It’s too easy to fall into the realm of wanting to make your car faster/better but it’s always at the cost of YOUR wallet obviously. Lol
Old Jun 21, 2023 | 08:23 PM
  #9453
I'm extremely happy with the 4.083:1 rear gears. Should have been a factory option for the 6MT.
I remember like 12 to 15 years ago, Ford offered three different rear gears in the Mustang GT, for no particular reason except that they could. I test drove two brand new GT Coupes, each with the 6MT, but one with the longer gears, and one with the shorter gears. The short-gear Mustang made a lasting impression on me, which is why years ago I made long plans to upgrade the gearing in my G.
Zero regrets. Best mod ever.
Old Jun 23, 2023 | 02:15 PM
  #9454
Josh South's Avatar
Josh South
I don't think its possible on the AWD is it?
Old Jun 24, 2023 | 10:42 AM
  #9455
socketz67's Avatar
socketz67
Community Builder
That's my understanding as well. On a 7AT RWD, it's a heavy lift using a diff from the transition models (07-08), but possible if you can find a low mileage unit. There's also flanges that need to be changed for the driveshaft. Again, doable but requires alot of research and planning.
6MT is the most straight forward to upgrade based on my understanding as the diff itself is larger? Not sure why Infiniti decided to use different diffs across the platform.
Old Jul 7, 2023 | 12:57 PM
  #9456
Josh South's Avatar
Josh South
Intake update
Just updating y’all on the intakes I modified. I got a new tune file from z1 and have been driving it for a week or so. It seems to be the same through the rev range until you hit 5-6k rpm’s and it just screams all the way to the 7900 rpm redline. It now squeals the tires going into second. Whereas before it would fall off at the top a little. Throttle response has increased a little from what I can tell. Seems it helped a good amount. Not sure I would spend the $600 for 3inch intakes but if you can get some used one for a good price I’d say it’s definitely worth it.
Old Jul 17, 2023 | 02:43 PM
  #9457
Muck_Man's Avatar
Muck_Man
Replaced the heater hose connector this weekend with a brass quick fit type unit from Home Depot. Mine was somewhat of a PITA to get out and did not fall apart like others on this forum. I only have 65k miles on a '13 so it might have been in better shape. It came out in one piece and was not brittal at all. Oh well.....one job done and piece of mind.
Old Jul 17, 2023 | 03:02 PM
  #9458
That's been on my mind for what seems like half a year now. Good for you.
Old Jul 17, 2023 | 06:02 PM
  #9459
socketz67's Avatar
socketz67
Community Builder
Living on the edge :-)
You were talking about the need to do this a month or two ago.
Old Jul 21, 2023 | 10:16 AM
  #9460
Annual NYS Inspection this morning. All is fine.
In New York, shops can no longer install exhaust modifications to the catalytic converters, but if you show up with the work done, all they are required to do is verify that a catalytic converter is part of the system, OEM or otherwise. I expect even that loophole will someday be closed, and I'll have to put my OEM cats back on. But for now...
Old Jul 21, 2023 | 10:25 AM
  #9461
rotarymike's Avatar
rotarymike
Moderator in Moderation
I mean, there's a current enforcement attempt to make modifying anything with emissions illegal even for off-road only vehicles, and that's interpreted as anything that increases power. Not the best link, but gets the gist: https://getjerry.com/insights/racing...sions-policies.
The idea that any street car has to keep the engine and emissions 100% stock even if converted into a race car and used off-road only.
Old Jul 21, 2023 | 12:26 PM
  #9462
KImChee's Avatar
KImChee
I installed my Z1 Long tube intakes. I already have Ark Grip Exhaust, and Berk HFC, so going to get a remote tube hopefully relatively soon.
Old Jul 25, 2023 | 11:05 AM
  #9463
joe32288's Avatar
joe32288
Just ordered a silicon hose master set from Z1, new CSF radiator, and a new set of hood struts (I've been propping that sucker up with the wrench from my spare tire kit for like two years - way overdue).
Old Jul 25, 2023 | 04:14 PM
  #9464
socketz67's Avatar
socketz67
Community Builder
@Rochester - what’s an exhaust modification to the catalytic converter? Replacement (HFC or race pipes)? Or is NY just checking to make sure any form of cat exists? CA just created a requirement that says if a car comes with a y-pipe, then it cannot be replaced with any other design such as X or H pipes. My exhaust guy for over a decade told me that he had a mustang and Camaro fail because of an x pipe he installed. I looked it up online and there are people complaining. Still not sure how any of the three change emissions out of the tailpipe unless scavenging has an effect on emissions?
Old Jul 25, 2023 | 04:18 PM
  #9465
Things keep changing. Unless my FI RHFC setup is CARB certified...
You can't use FI cats in California, and I believe the current NY laws require California compliance.
https://govt.westlaw.com/nycrr/Docum...ted%20pursuant
