Old Oct 26, 2022 | 12:10 PM
  #9181
BULL's Avatar
BULL
Moderador
Originally Posted by Lunchtime
G37 Coupe upper control arms on my G35/7 Sedan. Got me around +2 degrees of camber (gained)
I have a 2007 G35 sedan (V36 body). This the pretty much the G37 sedans too. So this information would be useful for G37 sedans as well.
Years back I replaced one of my upper control arms (UCA) with a coupe’s UCA. I noticed that the coupe’s UCA gave my car some positive camber. My sedan was at stock height at this time, so the additional positive camber wasn’t necessary. I put a sedan UCA back on, since I didn’t need the extra positive camber at the moment.
Fast forward to this year. I lowered my sedan a little over 1”, probably like 1.2 -1.4” lower. My fronts currently measure 27” (fender to floor). The car inevitably got some negative camber.
So I thought: Replace the sedan UCAs with the coupe’s UCAs, to perhaps gain some positive camber back into the fronts...for relatively cheap. I got a pair of the coupe UCA for $60.
Using the G37 coupe arms will be great too, as they will retain the aluminum feature of the double wish-bone suspension. (unsprung mass you know)
Yes, I checked before doing all of this. They are different Part Numbers
54524-JK000 upper right Sedan
54525-JK000 upper left Sedan
54524-JL00C upper right Coupe (G37 and 370Z)
54525-JL00C upper left Coupe (G37 and 370Z)
Once I got one side off. I lined up the back bolt holes as best as I could, and you can see that the front ball joints are longer on the coupe compare with the sedan. Coupe is on top
Concerns I had:
Will the coupe’s UCA affect caster?
Will the coupe’s UCA clear the Sedan body?
Can toe still be adjusted back to specs?
I bought an amazon DIY gauge to get my ‘before’ and ‘after’. Joke all you want. But this is just to help me get a before measurement and an after measurement. The difference between the two is the key information I’m going after.
With the DIY gauge:
‘Before’ measurement with Sedan UCA is -2.75 degrees (left picture)
‘After’ measurement with Coupe UCA is -0.75 degrees (right picture)
Both driver and passenger measured the same.
So -2.75 minus -0.75 -> gives us a total of 2 positive camber gained.
Great. But now I have to answer the concerns listed above. Took the car to get an alignment, and I’m glad to say that caster is in spec, toe can still be adjusted back to spec, and camber is in spec. And I have driven the car through speed bumps, did U-turns, etc. The coupe’s UCAs clear the sedan body.
The Shop’s alignment rack measures my front camber at -0.4 and -0.3 (via picture). So if we used the +2 camber value that I calculated at home, we can say that I initially had -2.4 and -2.3 camber to begin with.
In conclusion, you can use the G37 coupe/370z upper control arms on a Sedan, in order to gain around 2 degrees positive. Plus or minus some for margin-of-error.
Considering that Infiniti’s front camber Spec’s have a window of -1.1 to +0.4 degrees. That is a pretty large window. So If the coupe UCAs can get you back into that window. Maybe this could save you some money.
Hopes this helps. This has been on my mind for the past 3 years. And I’m happy to have prepared this for the community.
As someone who discovers random **** and decides to obsessively calculate the process and obtain amazing results I have to congratulate you on the job well done.
Funny thing is this is a common trick on some older suspensions however I dont think that ANYONE would have guessed the UCA would be any different. I mean 3/4 of the suspension is the same and these bars look exactly the same
You measured, tried, obtained data on your own and lastly confirmed with the alignment rack.
I will be using this trick pretty soon. Thanks again!!!!
Old Oct 27, 2022 | 12:48 PM
  #9182
BULL's Avatar
BULL
Moderador
Really cool info I found today which was the diagnostic menu.
I found I can reset my steering angle sensor through the infotainment system as well as access the rear camera while the vehicle is in motion.
Audio off, press setting while turning volume button, config adjustment, camera.
Old Oct 27, 2022 | 01:27 PM
  #9183
ILM-NC G37S's Avatar
ILM-NC G37S
@BULL , Friendly advice: Whatever you do in that diagnostic menu, DO NOT EVER press the option to RESET USET/ SYSTEM INITIALIZATION:
Doing so WILL ERASE your AV system and render it useless. Only CONSULT3 can reprogram the unit.
Many folks have pressed that option, and learned the hard way...
Old Oct 28, 2022 | 02:20 PM
  #9184
BULL's Avatar
BULL
Moderador
And to know I was a touch away from total Brickzation
Old Oct 28, 2022 | 02:23 PM
  #9185
Great info on the diagnostics screen. Although that warning makes me not want to even look, LOL.
BULL, what the heck is up with your dash plastics? How does that even happen?
Old Oct 28, 2022 | 03:50 PM
  #9186
BULL's Avatar
BULL
Moderador
The plastics were painted. I take it you mean the actual dash?
It's the best attempt at melting recovery, it looked like the Grand Canyon, almost everything that you see rough was cracked and exposing the yellow foam.
Possibly going to stay like that until the outside is looking proper again.
Old Oct 28, 2022 | 09:16 PM
  #9187
Muck_Man's Avatar
Muck_Man
Not to put salt in the wound but if it looks like that now, what did it look like before?? Geeesh How does that even happen?
Old Oct 30, 2022 | 05:50 PM
  #9188
EcstaticG37XS's Avatar
EcstaticG37XS
Decided to replace my battery since it's 4 years old and I changed it last time.
Almost every plastic fastener snapped and fell into the engine bay somewhere...the joys of working on a 10 year old car.
Old Oct 30, 2022 | 06:09 PM
  #9189
iCrap's Avatar
iCrap
Sound about right. Every time I work on my car I just pull out the box of new clips and plan to replace them.
Old Oct 30, 2022 | 06:12 PM
  #9190
Lunchtime's Avatar
Lunchtime
Thank you. Glad the write-up helps
Old Oct 30, 2022 | 09:23 PM
  #9191
thescreensavers's Avatar
thescreensavers
Did an Oil and Filter change and installed 25 row cooler. The mocal plate has a 180F thermostat but we shall see if I need to block it off. Slowly getting my car ready for a track day, suspension is next
Old Oct 31, 2022 | 10:25 AM
  #9192
BULL's Avatar
BULL
Moderador
Pretty much a crack all the way down to the yellow in any part you see that roughness, missing chunks and all. At the time finding a dash between my budget was just not going to happen so this was the result.
I have pictures of the before in my members ride.
Old Oct 31, 2022 | 10:29 AM
  #9193
thescreensavers
I started putting black E6000 into my cracks in the dash it's a little glossy but looks a hell of a lot better than yellow foam.
I had a big chunk fall off by my knee which looks terrible the repair makes it look a bit more hidden heh
Old Oct 31, 2022 | 01:51 PM
  #9194
BULL's Avatar
BULL
Moderador
JB black silicone dries fantastic and leaves a semi gloss finish. Fantastic for even the deepest gouges however not when the entire dash looks like it's had children.
That's kind of what I tried doing, somewhat of a coat and then went over it with a card, wet rags, pics, etc. That was pretty much the best I was able to do, it sucks because repairing dashboards are kind of a one time thing.
Old Nov 2, 2022 | 10:46 AM
  #9195
rotarymike's Avatar
rotarymike
Moderator in Moderation
Um - I can check the salvage yards up here for a dash - should be the same for any version of the same generation, no?
