Old May 1, 2022 | 09:58 PM
  #9031
SupraOfDoom's Avatar
SupraOfDoom
Had a big couple days. Let me tell you even with Z1's specialty tool for the rear diff bush removal that thing is NO JOKE. Especially if you are just on stands. It took 3 hours of me cranking on it while my bud kicked the breaker bar to free this. We some how managed to bend the ARP bolt but it made it out so I'm not complaining. I recommend paying someone lol! The diff itself was easy as hell in comparison. Takes 1 hour or so to take out, and about the same to put back in. 4.08 z1 lsd incase anyone is wondering.
Old May 1, 2022 | 10:09 PM
  #9032
2.2Lude's Avatar
2.2Lude
I couldn't imagine doing that job with a breaker bar on the ground.
I wouldn't even consider it a DIY without the press tool and, more importantly, AIR!
Props to you for getting it done though!
Old May 2, 2022 | 08:12 AM
  #9033
BULL's Avatar
BULL
Moderador
Helped a buddy do one on a base coupe. Undermined how much more difficult it will be on my 4WAS sedan.
Rear rack has to come out (Toe arms/buckets bolt to the rear rack)
Mine has been leaking for a minute now, have been contemplating sealing it.
My buddy's tool is a master kit and will slice through it then air hammer the collar.
It's the taking the rack out my issue since my rear bushing install will require an alignment afterwards.
Old May 2, 2022 | 09:44 AM
  #9034
RobC7's Avatar
RobC7
This was going to be my Spring project and I was planning on doing it on jack stands but now I am having second thoughts. Sounds like with no air tools it may be a nightmare.
Old May 2, 2022 | 09:56 AM
  #9035
thescreensavers's Avatar
thescreensavers
​​​​​A ratcheting breaker bar and a lubed up Grade 8 All-thread can get the job done, I've done it on two cars. The rear steering job sound terrible lol.
I have mine filled with epoxy and if I get the diff brace probably good enough
Old May 2, 2022 | 10:12 AM
  #9036
I had my new rear TPMS sensors synced up with the ECU this weekend, and I clay bar'd and sealed the passenger side of the car.
So much less than these other hard core projects you guys are working on, but at this point with the car all I'm doing is cleaning it.
And with that in mind, I've been using Seal & Squeal from Lithium Auto Care for a few years now. It's awesome.
Old May 2, 2022 | 11:47 AM
  #9037
SupraOfDoom
Nothing a few hours of misery and some pain and bruises can't get by. I'm hurting that's for sure. Have a friend for this project.
Old May 4, 2022 | 10:49 AM
  #9038
rotarymike's Avatar
rotarymike
Moderator in Moderation
I did mine on jackstands with no air tools... drill out rubber enough to get sawzall blade in there, zip around the bushing to get the middle out, then at 90* to cut the collar. A sharp cold punch started the cut end curling in and once I got that most of the way through the crossmember width the sleeve came out.
I think about 4 hours (after the diff was out). There were mechanic-type words said.
Old May 5, 2022 | 02:56 PM
  #9039
SupraOfDoom
I didn't want to risk damaging the housing with a cutter. It seems like there is no easy way DIY no matter what.
Anyway, today it's all back together with the Z1 subframe collars on as well! Z1 4.08 LSD and the Z1 diff bushings. WOW what a difference. I'm still going easy on it to break it in but this is how the car should have been geared from the factory in an ideal world! It's how it should feel.
Old May 5, 2022 | 03:12 PM
  #9040
rotarymike's Avatar
rotarymike
I didn't either... at first. I got over it.
Turned out that I didn't even score the subframe with the saw blade.
Old May 7, 2022 | 03:08 PM
  #9041
thescreensavers
Replaced the cooling module as my fans were on all the time, went with another OEM one as the aftermarket ones apparently fail off which I was not happy with.
The 3x100µF caps read 92.5(small) 91,91. I expected worse for being original part from 2011! But they are 125C rated. that was going to be my guess why the module broke but 🤷‍♂️
The PCB is also conformal coated and the whole thing is sealed up tight!
Old May 8, 2022 | 07:42 PM
  #9042
Muck_Man's Avatar
Muck_Man
Carnuba wax and coffee on a sunday afternoon. Now to put the duckfeet in the basement until next winter.
Old May 8, 2022 | 09:17 PM
  #9043
Epiphany's Avatar
Epiphany
That you, @Rochester ?
Old May 9, 2022 | 06:56 AM
  #9044
LOL, no. I noticed that, too. My duckfeet and snows are also cleaned and tucked away in the basement.
Old May 9, 2022 | 11:40 AM
  #9045
FrogmanKouki's Avatar
FrogmanKouki
Installed the Illusion Blueberry Akebonos, it was a successful weekend.
