Old Jan 5, 2020 | 11:48 AM
  #7471
CubanDre's Avatar
CubanDre
Originally Posted by RobC7
Changed the clutch fluid to DOT4, installed the midnight grill, cleaned the engine bay, conditioned the leather, and replaced the license plated bulbs with LEDs. Not a bad day!
What did you use to clean the engine bay, and leather? Ive been looking through the detailing forums just havent chosen a solution yet.
Old Jan 6, 2020 | 10:44 AM
  #7472
rotarymike's Avatar
rotarymike
Moderator in Moderation
Pulled the short shifter back out - the shorter direct feel was nice, but there is a little wobble in the fulcrum housing so it was hard to feel when it was actually in gear. The main problem though is that I have some neuropathy in my right arm and the additional effort was giving me a RSI-like numbness.
Tightened up exhaust bolts for the FI RHFC and CBE after 1 week on the car. No major loosening.
In other news I think I finally overstressed my rotor cuff when installing said exhaust.
Old Jan 6, 2020 | 11:00 AM
  #7473
Who makes your STS? One of the notable things about my STS is how absolutely rock solid it is in gear. The shorter throw is cool, but much more than that is the precise, unshaken click into gear.
Old Jan 6, 2020 | 11:06 AM
  #7474
rotarymike's Avatar
rotarymike
It's an Ebay knockoff of the B&M.
Let me rephrase - once you've found the 'gate' it is rock solid and direct. The shifter sits in a cup around the fulcrum that slides up and down to actuate the reverse lockout - both OEM and aftermarket. In the Ebay version, the 'cup' is a little loose on the fulcrum, so the top of the shift lever throw has some variability on where it is when the bottom end is lined up correctly to go into a gear. Supposed to fill the 'cup' with moly or silicone grease, and I didn't have any on hand at the time (and the center console is still out, so no big deal to add later). The actual effort to push from neutral into gear, especially 5 and 6, was enough that after 10 minutes of driving I was getting numbness in my hand and twinges in my shoulder. No doubt exacerbated by the aforementioned rotator cuff wear.
Now back on the OEM shifter it's butter smooth again. I think I need something halfway between the 40% throw short shifter and full throw oem, if I'm going to go that route. But honestly I don't think the short shifter was making my shifts actually any faster, what with increased effort and initial gate lineup variability. (replace those 4 words with 'slop' - I'm in lawyer mode this AM.)
Old Jan 6, 2020 | 11:47 AM
  #7475
I think the argument about "faster shifts" is mostly a tag-along rationale when people get a short-throw shifter.
As for increased effort... that's nothing I would describe, but I'm also not saying you're not feeling that. If I could toss in a few more double-negatives, I would, LOL.
Old Jan 6, 2020 | 01:10 PM
  #7476
2GoRNot2G's Avatar
2GoRNot2G
So... it's the Zerk fittings for the Hotchkis frame brackets that's the problem, not the aftermarket bar itself? Is that what you're saying?
That's good info for anyone planning on an aftermarket tray.
Yeah, the zerks were the only spot I have fitment issues with. Although, I have the TBW under tray, so the fitment for other aftermarket trays may be different. But, as I mentioned, it's a fairly easy fix to just drill a couple of holes were the zerk fittings make contact with the under tray. Here are a couple of pictures of the zerk fittings contacting the TBW under tray. I couldn't find any pics after I drilled the holes in the under tray, but I can always take a couple pics if someone wants me to.
Old Jan 6, 2020 | 01:22 PM
  #7477
Those sway bars are beautiful. Paint is wearing off my Eibachs after all these years.
Old Jan 6, 2020 | 07:02 PM
  #7478
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Interesting Adrian, I need to take a photo of mine. Last time I checked, I had like 5 mm more clearance.
Old Jan 6, 2020 | 08:07 PM
  #7479
2GoRNot2G's Avatar
2GoRNot2G
Thanks for the nice words. I do love the candy apple red powder-coat! I don't really have any experience with Eibach, but the original powder-coating on the Hotchkis sway bars was holding up pretty well before I had them redone... even where the bushings ride on the bar there was very little wear. My powder coating guy actually had to send the bars off to have the old coating removed with a chemical dip.
Old Jan 6, 2020 | 08:12 PM
  #7480
2GoRNot2G's Avatar
2GoRNot2G
More good info there on the under tray.
It's not a high priority for me, bit odds are when I get one it will be TBW. I like everything I've ever seen about that tray. I don't have Zerk fittings for my sway bar brackets & frame bushings, but I like collecting miscellaneous info like this. Things get repeated here, because car forum.
I wonder... my engine is lowered in the bay by a half inch because if the aftermarket motor mounts. I wonder if that impacts fitment here?
Originally Posted by hexotic
Shouldn't affect fitment. It mounts in place of the OEM one, so if that clears, TBW will too 😁
Yeah, I agree that the lower engine mount shouldn't affect the clearance between the sway bar and under tray, since both of those mount to the bottom of the sub frame which wouldn't be affected by the lower engine mounts.
Do you have the same Hotchkis sway bars with the billet mounting brackets, Andy, or do you have the stamped steel brackets? I think the billet mounts are thicker, so that could be the difference.
Old Jan 7, 2020 | 09:49 AM
  #7481
Aeroneer1's Avatar
Aeroneer1
Originally Posted by RosaP-37S-G
Nice. What brake rotors/pads do you have? In the market for new ones, probably don't have the funds to do Akebano conversion.
Old Jan 7, 2020 | 02:38 PM
  #7482
slartibartfast's Avatar
slartibartfast
Now you need to step up your game in the tire department.
Old Jan 7, 2020 | 02:52 PM
  #7483
CubanDre's Avatar
CubanDre
LOL Savage!!
Old Jan 9, 2020 | 10:40 AM
  #7484
RobC7's Avatar
RobC7
The Engine bay was quite dusty so I used a microfiber towel and some soapy water. For the leather I had used Chemical Guys cleaner and conditioner.
Last night I installed the Bellworks Differential Brace. Car feels extremely solid now, no more drive-train slop when getting on or getting off the throttle hard. Overall the car is smoother to drive, highly recommended for anyone with a 6MT. Next project will be to fill the blown bushing with epoxy as I won't get around to replacing it for quite some time.
I really need to post an introduction and start posting some pictures of the progress.....
Old Jan 9, 2020 | 10:45 AM
  #7485
Yep. All you need in the engine bay is time and elbow grease.
That diff brace is a great mod. Good for you.
However, not sure I would install it without already having secure diff bushings. You're asking a lot out of the brace bolts now.
Agreed. Go for it!
