The Sedan Exhaust Thread
Old Jan 31, 2017 | 05:54 PM
  #316
jgronline's Avatar
jgronline
Has anyone tried the Magnaflow cat-back exhaust? It has an X pipe and 2.25" mandrel bent pipes.
$1063 on Amazon
https://www.amazon.com/MagnaFlow-168.../dp/B001O02LAM
Old Feb 1, 2017 | 08:36 AM
  #317
FrankRoshi's Avatar
FrankRoshi
Clips of the 2010 & 2013 with Invidia Q300
The clips sound similar to me but the cars don't sound the same on the road, either inside the cabin or out...
That's why I'm making the Monstrosity... I want more volume and sexual expression from her... Mine's the '13 in case you're new...
Thoughts?
BTW, the custom exhaust guy said he'd do the job if I find stainless elbows, and accept the fact non-tig welding would rust unless painted. I'm going to do it.
Frank
Old Feb 1, 2017 | 12:13 PM
  #318
guy from norcal's Avatar
guy from norcal
Frank, I like your son's better. sounds a little deeper.
Old Feb 3, 2017 | 08:46 AM
  #319
jgronline's Avatar
jgronline
$1063 on Amazon
So no one has any thoughts on this exhaust? No one has tried it?
Old Feb 3, 2017 | 08:53 AM
  #320
Sleeves and clamps, instead of bolts, gaskets and flanges. And a computer generated image, instead of actual photos, even on their own website.
And if you're having a difficult time finding reviews... Danger, Will Robinson.
Old Feb 3, 2017 | 01:16 PM
  #321
MaQG37's Avatar
MaQG37
Stillen uses all Magnaflow components for their exhaust. This looks identical to the stillen setup with the exception to utilizing an X pipe. Given it's using quality components, X pipe, and a reasonable price. I think it's the better exhaust in its price range against the competitors in that bracket.
Old Feb 4, 2017 | 06:46 PM
  #322
jgronline's Avatar
jgronline
My old Buschur Racing 3" exhaust on my GVR4 had sleeves and clamps. Less weight and easier to make sure it is aligned. I was more worried about the sound level but I would think it would have the best flow for a cat-back system.
Old Feb 4, 2017 | 10:27 PM
  #323
FrankRoshi's Avatar
FrankRoshi
Who needs a welder? All you need is testosterone and power tools...
Flex hose?
Sleeves and clamps?
What say you? Got impatient. Started cutting...
I could be growling tomorrow... but for Super Bowl parties...
Old Feb 6, 2017 | 04:52 PM
  #324
2GoRNot2G's Avatar
2GoRNot2G
Coming along nicely. I say buy a welder and finish it yourself!
Old Feb 6, 2017 | 05:47 PM
  #325
FrankRoshi's Avatar
FrankRoshi
Ok... I will... headed for Harbor Freight now...
The duct tape is temporary. If it'll duct tape, it'll weld!
This will require a little more cutting and fitting...
I accept your challenge!
Old Feb 6, 2017 | 06:48 PM
  #326
guy from norcal
Looking good frank.
Old Feb 7, 2017 | 11:18 AM
  #327
FrankRoshi's Avatar
FrankRoshi
Custom MeganVidiaManzo Hybrid Update
Harbor Freight- $99!
Organization is the key to success...
The flange on the left rail of the jig is one of two that came from the Invidia x-pipe. I'm going to put them between the forward part of the x-pipe and the rear of the cut off Megan y-pipe. I want to make the system installable in two pieces.
Getting close. Two more cuts and I'm ready to weld!
Old Feb 8, 2017 | 03:49 AM
  #328
ZahyMatar's Avatar
ZahyMatar
No flex pipes? That would help with getting it aligned while you're installing the exhaust if anything happens to be off. Looking good though!
Old Feb 8, 2017 | 08:19 AM
  #329
While that's true, a flex pipe gives you a little fitment slack, there's something you should be aware of while you wait in queue for your new Fast Intentions exhaust...
...FI doesn't use a flex-pipe.
Old Feb 8, 2017 | 08:24 AM
  #330
ZahyMatar's Avatar
ZahyMatar
I'd say if you're going the "DIY" route, he'd benefit much more from the flex pipe.
My ETA for the FI exhaust is April 14, 2017... Not too bad
