Steering to easy at low speeds?
Old Jan 10, 2016 | 11:16 AM
SonicVQ's Avatar
SonicVQ
My previous car was a 2001 BMW 530, which had fantastic steering feel and gave lots of feedback. You always knew what the front was doing.
In comparison to my G37 Sport the steering is too over boosted at speeds below 60 MPH. In looking at how the variable assist works, it would be very easy to reduce the boost and get more feel.
Am I alone in feeling it is over boosted and has anyone modified the system to reduce power steering boost at all speeds?
Old Jan 10, 2016 | 12:21 PM
Maximus12105's Avatar
Maximus12105
Personally I haven't felt like my steering has felt over boosted. However, my past three cars have been Infiniti's ('07 G35S, '11 FX35, '11 G37S LE - current) so it may be something I'm just used to. I realize that's not very helpful though.
If you figure out a simple way of dialing it back, I think it'd be interesting to try it!
Old Jan 10, 2016 | 12:57 PM
ETrev's Avatar
ETrev
Take into consideration that what you're feeling may be oversteer, and not overpowered steering. In fact, from what I've read the steering of these cars is one of it's most applauded features.
Have you installed new swaybars yet? If not, you should. It changes the handling of the car entirely. You will find many many users on here who stand by that.
Old Jan 10, 2016 | 01:33 PM
Silver37's Avatar
Silver37
You'll need to be running summer tires to get the heavy feel to the steering that you want. If you run all season tires on the S model, you'll get a much lighter feel than the OEM summer tires that came with the car. I would assume that heavier sway bars would make steering heavier regardless of which type you use.
Old Jan 10, 2016 | 06:59 PM
qmantran's Avatar
qmantran
Over steer? The hell are you talking about. OP is talking about power steering assist and you come in here talking about oversteer and sway bars?
Two very different things that has nothing to do with one another.
Back on topic.
My last car was a 08 TL and the steering in that thing at low speeds was very heavy at low speeds. When I let other people drive it they would all usually point out how heavy the steering feels at low speeds. I was used to it and never thought nothing of it.
Than when I got my G37S RWD sedan the first thing I noticed was how light the steering felt at low speeds. It was a huge difference compared to my TL. I actually like it this way.
Old Jan 10, 2016 | 08:50 PM
SonicVQ's Avatar
SonicVQ
Thanks for your input, but it is not oversteer. The steering wheel is too easy to turn at low speeds, at least for me. We all have different preferences.
Sway bars help to increase roll stiffness which is not related to the steering effort.
Old Jan 10, 2016 | 08:52 PM
SonicVQ's Avatar
SonicVQ
After reading the STC section of the FSM, I will scope the power steering solenoid valve and document the duty cycle at different vehicle speeds and engine RPM. Ideally I would like the power steering assist to be much less and CONSTANT.
A lower average voltage at the PSSV (~2 volts) = the reduced assist we experience at 60 mph.
Something like this may be the solution:
AutoSpeed - Modifying Speed-Sensitive Power Steering
Old Jan 10, 2016 | 09:35 PM
takeapieandrun's Avatar
takeapieandrun
I was driving a Honda Accord and sometimes my mom's MDX before the G. By comparison the G has so much better steering feedback, sometimes when I go to the gym and go hard on arms its a chore hahaha.
Old Jan 10, 2016 | 10:41 PM
iCrap's Avatar
iCrap
The strange thing with my car is when it was stock the steering was REALLY heavy. At low speeds it was almost too heavy.
But after I put in the lowering springs the steering is really light and easy to turn.... I don't get it. I prefer it now though.
Old Jan 11, 2016 | 08:44 AM
You may have altered your caster when lowering, especially if you added aftermarket camber arms. Less caster will make it easier to turn off center.
SonicVQ
Jun 2, 2022 06:01 AM
TastefullyDoneG
Dec 31, 2015 01:39 PM
mjnoles1
18
Dec 24, 2015 11:02 AM
Gthangftw
Dec 17, 2015 08:09 AM
warpeacelove
Dec 15, 2015 01:47 PM
