SEDAN | Official Aggressive Offsets & FAT Tires
Old Aug 3, 2020 | 03:18 PM
  #451
userisunnamed's Avatar
userisunnamed
Sedan with 19x10.5 rear on 275s?
I have a 13 G37S Sedan on Swift Springs and OEM Struts
Just picked up some 19x9.5 +22 Front and 19x10.5 +22 rear Volk TE37's and was wanting to go with a 245/40 F 275/35 R tires.
Is this too aggressive for a Sedan in the rear?
I am ok with running negative camber but will just go with 265's if it's easier.
Tires i was thinking about are either Hankook V12 Evo 2's or Achillies ATR Sport 2's for reference.
From what i can tell they fit the Coupes perfect with this set up as seen here: https://www.fitmentindustries.com/wh...auto-coilovers
Thanks
Old Aug 4, 2020 | 03:42 AM
  #452
Gill408's Avatar
Gill408
Thanks
the car your using as reference is a coupe. The sedan has less fender clearance. I have 255/35/19 on 19×10.5 +22 with -3 camber just to barely clear the fender
Old Aug 5, 2020 | 11:03 AM
  #453
userisunnamed
What camber kit are you using to push it to -3?
Old Aug 5, 2020 | 11:06 AM
  #454
GofToronto's Avatar
GofToronto
Originally Posted by projectpanda13
the 8.5” +30 will clear the front Akebono for sure.
the 9.5” +38 almost clears the front so I feel it should clear the rear calipers.
you should be good.
thank...!
Old Aug 5, 2020 | 11:42 PM
  #455
Gill408's Avatar
Gill408
I'm using Z1 camber arms.
Old Aug 7, 2020 | 10:57 AM
  #456
userisunnamed
Looks Good
Originally Posted by PNW_IPL
Thanks. Its actually Garnet Ember a51. It's an 08 color.
They fit fine.
No rubbing
19x9.5 +12 245 40
19x10.5 +22 265 35
Natural camber stock arms rear -2.5
Front camber stock arms -2.2
Car looks awesome, i have pretty much the same wheels and deciding on tire choice. Which tires are these ? Which suspension are you on?
Thanks
Old Aug 14, 2020 | 10:28 AM
  #457
ToXIc's Avatar
ToXIc
anyone with rears with anywhere around the following specs?
10.5 +30 to +35
Old Aug 14, 2020 | 10:47 AM
  #458
projectpanda13's Avatar
projectpanda13
10.5 +30 to +35
https://www.myg37.com/forums/wheels-...ml#post4147175
I had 10.5 +35 with 275 in that post.
Old Aug 14, 2020 | 05:03 PM
  #459
ToXIc's Avatar
ToXIc
i like that thanks
Old Aug 31, 2020 | 08:28 AM
  #460
projectpanda13
18x9.5 +15 255/40
18x10.0 +38 285/35
Fronts poke but rears are perfect. I wish the 9.5" +38 cleared the Akebono, but only the +15 in a 9.5" clear.
Old Sep 3, 2020 | 12:21 PM
  #461
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
18x9.5 +15 255/40
18x10.0 +38 285/35
Do you have a side profile shot of the poke? I've been eyeballing RPF1s for a while now, but cant pull the trigger because I cant seem to find a size that I like how it sits on the G. AWD also a limiting factor.
Old Sep 3, 2020 | 01:03 PM
  #462
projectpanda13
It stick out a good bit in the front and had ti stiffen my shock damper setting since it chewed up my bumper tab. I'm going to camber my fronts a bit on my next alignment. 9.5 +15 will stick out more in the back. Matt has a square setup on his sedan with 265 i believe.
Old Sep 3, 2020 | 01:35 PM
  #463
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Yeah, I'm looking at 265 square for the tires with my current setup, but only once my z1 upper control arms come can I actually pull it off. Clearing the Akebonos without spacers is my biggest concern with the Enkeis.
Old Sep 3, 2020 | 03:43 PM
  #464
PNW_IPL's Avatar
PNW_IPL
Thanks
Cheap accelera phi. ok all season.
Old Sep 3, 2020 | 03:47 PM
  #465
PNW_IPL's Avatar
PNW_IPL
running square now. 19x10.5 +12 +22 rear.
265 35 square
