2012 G37x sedan help
Old Mar 17, 2015 | 12:22 PM
nyczmadman's Avatar
nyczmadman
So i have a 2012 g37x sedan and i noticed last night that the button lights on the dash werent lit. Turned off the car and turned it back on and still not on. My lights are on can anyone help??
Old Mar 17, 2015 | 01:15 PM
ay37's Avatar
ay37
you check your dimmer switch?
Old Mar 17, 2015 | 08:16 PM
nyczmadman's Avatar
nyczmadman
Dont think its the dimmer thing. tails and the license plate werent lit either. idk what to do?
Old Mar 18, 2015 | 01:15 AM
RavensMinded00's Avatar
RavensMinded00
I would sat checking your light fuses. More than likely a fuse issue and a $5 fix. As to why it may have blown in the first place, that's another story.
Old Mar 18, 2015 | 06:47 AM
CRiME's Avatar
CRiME
I had this issue on an '05 maxima. The console was dark and the tail lights were out. I found that the 15a tail lamp fuse was blown. I replaced it and found that it would blow again randomly. I eventually traced the issue to a faulty dome light switch. I havent read of the dome light switch being a problem in these cars, but Check & replace the fuse if blown, then go from there.
If the fuse blows again, start checking your harnesses etc. Be sure not to replace the fuse with a higher amperge than specified, because if there is a wiring issue it's better for a fuse to blow than to have melted wires or worse. I Hope you can find something, electrical issues can be tough to pinpoint.
Old Mar 18, 2015 | 11:55 AM
nyczmadman's Avatar
nyczmadman
thanks guys. where is the fuse located?
Old Mar 18, 2015 | 01:20 PM
mdmill1's Avatar
mdmill1
Drivers side kick panel...
Old Mar 18, 2015 | 08:35 PM
RavensMinded00
Agreed. Additionally, check your manual and the net for a fuse diagram (model and year specific )
rbgrant
Buying & Leasing
Nov 12, 2020 11:53 AM
Troop12
May 9, 2018 02:40 PM
dak5305psu
Oct 5, 2016 09:34 PM
bkouba88
16
Aug 21, 2015 12:44 AM
delfinparis
Aug 8, 2015 06:09 PM
