Trouble up a steep hill
Old Nov 23, 2014 | 11:54 AM
NyC_G37x's Avatar
NyC_G37x
Last night I was going up a very steep hill. I was initially going about 25mph before going up. Then when I gave it some gas It felt like I was stuck on first gear and not going nowhere. I made it up. Then the car was ok on the downhill but on the next turn I had to take was another slight uphill and it happened again. The car was just reving when I stepped on the pedal. I pulled over. Turned off the engine and restarted again. Then went on to drive another 80 miles fine. What could of happened? Anyone have an idea on the cause?
Btw... It's a 2010 G37x with 30k miles
Old Nov 23, 2014 | 12:15 PM
socketz67's Avatar
socketz67
Community Builder
Interesting. I've never had this exact issue, but I live in an area of rolling, fairly steep hills (my kids call it a roller coaster). Sometimes, when going around 25mph and attempting to go up the steepest hill near my house, the transmission seems to free rev while it's hunting for a gear since it's in 4th gear based on the downhill ride from the previous hill. If I stomp on the gas going up the hill, it will adjust quickly, but since it's residential and frowned upon by the neighbors, I try to keep an even pace. The car does struggle in these types of low speed scenarios.
Old Nov 23, 2014 | 02:04 PM
vqsmile's Avatar
vqsmile
Were the engine and transmission up to operating temps when this happened?
Old Nov 23, 2014 | 02:17 PM
NyC_G37x's Avatar
NyC_G37x
I drove it for 30miles. Turned it off for 45minutes. Drove it for 1/2 mile then it happened.
Old Nov 24, 2014 | 10:12 AM
BLamb's Avatar
BLamb
have you gotten your transmission re-flashed to the latest update? I used to have some issues while turning left and accelerating at that speed. would get some hesitation on hills, but like socketz67 said a little extra gas would get it to downshift pretty quickly and take off up the hill pretty quickly. It did seem to "kick into gear". After the update I've had no issues and I drive some pretty steep rolling hills every day to and from work.
Old Nov 24, 2014 | 12:02 PM
NyC_G37x's Avatar
NyC_G37x
I haven't gotten my transmission re-flashed. How much did it cost? I should definitely look into getting it updated. Thanks for the input.
Old Nov 25, 2014 | 10:08 AM
BLamb's Avatar
BLamb
if you're under warranty it should be free. Just ask the dealer to update the transmission software and the new ECU flash as well. They can check your software and update to the latest versions. there's a massive thread on here about the TSB. if you're out of warranty I'm not sure, they may do it out of goodwill if you're a regular customer or they may charge a few hundred dollars for "labor" while your car sits there and installs the software.
mjnoles1
Oct 4, 2015 10:27 PM
Awgd8
Sep 30, 2015 06:22 PM
MrRiv
Sep 29, 2015 04:59 PM
k19g37x
Sep 29, 2015 02:46 PM
Slapshot1
Sep 27, 2015 08:40 AM
