Has any one changed their car battery yet?
Old Nov 17, 2014 | 11:23 AM
G37Xtreme's Avatar
G37Xtreme
Originally Posted by serega13
Just changed battery on wife's 2009 yesterday. Did it myself, only took like 10 minutes tops, easiest job there is other than changing air filter. Also advanced auto parts gives 20% discount if you order online and use code EXCM4, you still pick it up from the store, just get additional 20% off.
I absolutely LOVE Advance Auto. I've been doing this trick for the past few years. I NEVER buy anything in the store anymore, unless it's like $5.
I recenly bought a $27 socket set for removing rounded bolts for $17 (with $10 coupon) and picked up in store the same day.
Advance Auto always has really good coupon codes...I happened to use the $10 off any $25 item coupon. There are some even nicer ones if you're spending right at $100.
Just do a search for Advance Auto coupon code, and most often Retail Me Not is the website with them.
Old Nov 17, 2014 | 12:34 PM
Alcaponed's Avatar
Alcaponed
I changed mine out at around June. I used AAA so they drive to wherever I am and installl an Interstate battery for me for around 140. And they have pro-rated replacements similar to that of Costco. If the battery dies within the first three years it's completely free and they come to your house to exchange it.
Old Nov 17, 2014 | 02:33 PM
stockae92's Avatar
stockae92
I have a '08 G35s 70k miles still running on original battery. The dealer checked it out and said it was good. And I am experiencing on slow crank yet.
Old Nov 19, 2014 | 11:37 AM
Detail's Avatar
Detail
I will never buy an optima battery again. The last 3 or 4 I put in my talon were absolute crap.
From here on out I'm only buying normal batteries and using the advance auto coupon "trt41". That's $40 off a $100+ battery.
Old Nov 19, 2014 | 11:48 AM
G37Xtreme's Avatar
G37Xtreme
Is this an ever-lasting coupon? Also, is it battery specific, or $40 any $100 purchase?
Old Nov 21, 2014 | 07:41 AM
acesk8er's Avatar
acesk8er
Just had the original battery replaced in my 2011. The car was still starting OK but the battery voltage dropped to about 11.9 V very quickly with the ignition off. Load test result was "needs charge"... This was the longest lasting battery I've ever had. Here in South Florida the heat usually kills them off in 2 years. Get it changed - it's not worth the aggravation of getting stuck somewhere.
Old Nov 22, 2014 | 12:29 PM
monytx's Avatar
monytx
Originally Posted by NyC_G37x
Does the adapter come with it or do I Have to purchase it separately?
Sorry for the late reply. It does come included with the battery.
Old Nov 22, 2014 | 02:27 PM
'11G37S's Avatar
'11G37S
A 1/4 mile @ a time
Just changed mine yesterday. It died on me early Friday morning, and had been recharged every time tmit was at the dealership for the past couple of months. I guess the cold weather did it in.
Old Nov 22, 2014 | 05:43 PM
Yazovets's Avatar
Yazovets
I replaced the battery on my 2009 G37x last month since the original was getting weak. I don't want to begin the winter with a weak battery.
Old Nov 23, 2014 | 09:49 AM
forrmark's Avatar
forrmark
I live in South Florida too, and I have never had a battery last only 2 years. Mine last at least 4 years and a few even longer. I also have a 2011 G and the original battery is fine.
Old Nov 23, 2014 | 11:22 AM
gugarci's Avatar
gugarci
I wound up replacing my battery. My cranking power was low. Probably my own fault since due to my own stupidity this past summer I had to jump start my car one day. I had an Interstate Megatron Plus installed.
Old Nov 24, 2014 | 05:05 PM
Jethro's Avatar
Jethro
I had my 2009's battery replaced last winter. Car just wouldn't start, and after a jump and driving around for forever, it would not hold a charge. I also had my dealer do it with an upgraded cold starting amps because the cost difference was negligible.
superjoey
31
Mar 22, 2023 11:56 PM
GXXXVII
General Tech Questions
Dec 11, 2021 08:58 AM
Thedbarz
33
Feb 9, 2016 12:05 AM
bikerjosh
Aug 19, 2015 11:26 PM
Skeletor06
Aug 2, 2015 12:54 AM
