Sedan Chat Thread
Old Dec 26, 2018 | 06:56 PM
  #12661
rotarymike's Avatar
rotarymike
Moderator in Moderation
rallylights.com is my go-to for lighting info and bulbs and housings (for my cars that take the old rectangle sealed beams). They don't list nissan or infiniti by name, but you can look up the bulb numbers easily enough.
Also from here: https://www.hidplanet.com/forums/for...f-lumen-output
For one person 300-500 Lumens might be low loss, while for others too much. Generally speaking (based on Philips datasheets) and avg. 4100-4300K bulb (85122) can produce 3100-3400 Lumens, while a 4800K (85122CM) goes down to 2800 Lumens and 5800K (85122WX - Ultinon) goes down to 2400 Lumens. I can assure you that there is a noticeable difference in the output between these bulbs.
If you plan to go at 5000K try an OEM solution (like 85122CM or Osram Cold Blue etc.). You WILL LOSE Lumens, but still you will keep the major quality characteristics of the OEM bulbs. If you chose ANY a/m bulb higher than 4300K you'll be having a blue tinted output (even with 5000K bulbs), plus all the minuses from the lower quality of the bulb (compared to any OEM one). This is based on my personal experience
For example: HL88409 H9 12V 65W OPTILUX Extreme XY Yellow Bulbs, pair | Rally Lights should 100% replace the stock fog light bulbs.
By the way, do the stock fog lights just suck? I put one of these bulbs I had from another car in my G37 housing to see if it improved things. Nope. Nada. Basically a yellow tinge around the headlight beam is all I get. Is the stock beam pattern on these just junk?
Old Dec 26, 2018 | 07:43 PM
  #12662
Yes. I went with Morimoto full replacement fogs years ago, couldn't be happier.
Thanks for the confirm on the 5000k, Mike.
Old Dec 26, 2018 | 09:35 PM
  #12663
rotarymike's Avatar
rotarymike
are the morimotos LED or standard incandescent based?
Old Dec 27, 2018 | 12:30 AM
  #12664
qmantran's Avatar
qmantran
Rochester if you're looking for simple replacement bulbs than I would suggest these Morimoto D2S bulbs.
https://www.theretrofitsource.com/d2s-morimoto-xb-hid.html?preselect=49469
2 year warranty and their customer support is great.
However, if you're looking for a upgrade I would recommend Osram Cool Blue Boost bulbs. They can be found for under $150 on ebay. I found some for $115 before.
I didn't buy them because I'm running Cool Blue Intense bulbs atm and I plan to ride these out until I really need to change them. Going on 3-4 years now and I still notice every night how bright they look.
My brother has the 35w morimoto hid kit in his camry with projector headlights. He has the 5500k bulbs. My osram cbi outperform the morimotos in every way. Not a equal comparison though. His camry has aftermarket projector headlights vs my oem headlights with sti-r clear lens swap upgrade.
I still recommend morimoto for value/ performance and good customer support when you need to use warranty..
Osram Cool Blue lineup for a upgrade.
Old Dec 27, 2018 | 07:19 AM
  #12665
LED
Check out the Retrofit Source.
Old Dec 27, 2018 | 07:34 AM
  #12666
Thanks, qmantran! The XB35 at 5500K seems right up my alley at $50, and I already have a good vibe about TRS.
The 35w is a direct bulb replacement, right... out with the old, in with the new?
Old Dec 27, 2018 | 04:13 PM
  #12667
qmantran's Avatar
qmantran
Correct. Getting to the bulbs is simple too. Removing both front wheels will give plenty of access room. Just pull back the fender liner and the bulbs are behind the dust cover. Simply twist off the dust cover counter clockwise and you'll see the igniter plugged into the back of the bulb.
Remove the igniter by also turning it counter clockwise. It turns maybe 1/8th turn and you can feel it when it unlocks.
The d2s bulb is held in by a retaining clip. This clip applies a constant spring pressure on the bulb holding it in place. To remove it you have to put a finger on the end (far left or right, I don't remember) where theres a metal tab. Press the tab away from you and than pull down or up (also don't remember). This releases the retaining clip from the lock position. Swing it to the side and pull out your old bulbs.
the retaining clip will stay in the headlight. It should not fall and get lost.
d2s bulbs must be installed in the correct orientation. Simply line up the notch cutouts on your bulb with the headlight.
having a flash light will help. 0
Old Dec 31, 2018 | 02:04 PM
  #12668
rotarymike's Avatar
rotarymike
So had a VQ35HR fuel rail arrive while I was out for christmas. Damn, those rails are beefy - basically 3/4" steel square tube main galleys.
Almost had a side trip to pull a VQ35 lower intake manifold from a 2008 G35 but wife nixed that idea due to travel time. And to be fair, my only tools were a leatherman and a pair of scissors. I mean, I could have gotten it, but...
So 1 part away from putting the VQ35 upper manifold in the car. I got teased by my local LKQ with a 2008 FX35 but that is still the 35DE engine according to wikipedia. Shame, they have 40% off this weekend too...
Old Jan 9, 2019 | 11:22 AM
  #12669
Hey guys, there's a new Group Buy thread for a bolt-on brace on your rear diff:
https://www.myg37.com/forums/group-b...ial-brace.html
Old Jan 23, 2019 | 08:12 PM
  #12670
SupraOfDoom's Avatar
SupraOfDoom
How much do you guys think I could get for my OEM Akibono's, with pads/rotors with tons of life on them, and even the front baffles as some sort of sport upgrade kit for someone?
Old Jan 23, 2019 | 08:29 PM
  #12671
rotarymike's Avatar
rotarymike
I'd love to swap my 2013 non-logo sport brakes (they're powdercoated black, btw) with actual labeled Akebonos. Red would be even better...
Old Jan 23, 2019 | 10:10 PM
  #12672
slartibartfast's Avatar
slartibartfast
Supra, search the classifieds for Akebono and see what others got for theirs.
Old Jan 24, 2019 | 07:24 AM
  #12673
SupraOfDoom
I've seen the prices of just the calipers but I thought I could maybe get more if it was in an almost complete upgrade kit. Most people don't offer that.
Old Jan 24, 2019 | 07:32 AM
  #12674
I don't understand what you're wanting to do here. Swapping brakes because of decals?
Old Jan 24, 2019 | 10:00 AM
  #12675
Baadnewsburr's Avatar
Baadnewsburr
given the calipers sell for 600-800ish probably 900-1000?? just a wild guess...I think the reason people dont usually sell them together with selling the rotors is shipping is so expensive by the time you add that cost its hard for private sellers to compete with placing selling them new that subsidize the shipping ...buyers usually scoop up the calipers fast vs, for rotors they tend to sit for a while unless someone picks them up locally
I'd love to swap my 2013 non-logo sport brakes (they're powder coated black, btw) with actual labeled Akebonos. Red would be even better...
I painted my calipers black a while ago, you can get decals for a few dollars online...I got mine here Decals a while ago I think I got "copper" coloured ones...just spray a high heat clear coat on after to make cleaning easier....ebay also has options but somtimes they screw up the sizing especially for the rears...there is also a template floating around somewhere if you want to get them printed locally
