Sedan Chat Thread
2018 Subaru... three more years of payments, 12000 miles.
2014 Nissan... zero payments, 27000 miles.
2011 Infiniti... zero payments, 39000 miles.
It will all work out somehow. I shouldn't gin up worry about things like this, but it's what I do.
Exactly. Chatter goes away as soon as I push the clutch pedal, and comes right back if letting out the pedal while in neutral. However, I don't hear the noise when releasing the clutch pedal into 1st gear, even when doing it as gently as possible, but that's hard to tell because the engine/exhaust is somewhat loud.
Planning on getting a mechanic's analysis on this problem next month.
Pretty sure the situation describes a failing input shaft bearing, not the throw-out bearing. Either way, pretty disappointing for a transmission with only 39k miles on it.
It definitely could be the input shaft bearing, but my bet would be on the throw-out bearing. The throw-out bearing is a much more common failure item and your car has way too little mileage to be at the point you'd need to replace the input shaft bearing.
From my experience, when the throw-out bearing first starts to fail the noise will usually be present when the bearing is turningbut not loaded so it will usually go away when you rest your foot on the clutch pedal and/or fully depress the clutch pedal (loading the throw out bearing)… If it still makes the noise with the clutch pedal fully depressed then the throw-out bearing could be completely gone and/or it could also be a bad pilot bearing, which would also get replaced when the clutch is replaced. If it makes the noise all the time regardless of the clutch position then its more than likely a bad input shaft bearing, which can also be replaced when the clutch isremoved.
Here’s a good site that explains common clutch noises that you can check out.
https://www.yourmechanic.com/services/loud-noise-when-using-the-clutch-inspection
In the context of unexpected repair bills... $1000 sucks big time.
I understand replacing the two bearings, but why replace the clutch and flywheel if it's just the bearings that are going? These are not parts I want to upgrade. Driven a few cars with aftermarket clutch/flywheel mods, and I genuinely don't want this. It certainly makes the car more aggressive and is a performance mod, but it's also freaking brutal, and I don't like it.
This is always a tough decision because the cost of the replacement bearings is relatively low compared to the time and cost to replace them. Most people figure if they are taking the time to pull the tranny or paying someone hundreds of dollars to pull the tranny then the might as well replace the clutch and resurface the flywheel while they are in there. Otherwise you are going to be paying someone another $600 or so in a couple of years to replace the clutch. Even if you aren't upgrading it would definitely save on future maintenance costs.
Happy Friday y'all.
I've been experiencing an intermittent loss in clutch pressure the past couple months. I checked the clutch fluid today and noticed it's a tad lower and a bit darker than when it was put in last December. I'd like to get another flush/replacement done, but this time I want to avoid the dealership and the $450 they charged me last time. How much should an independent mechanic charge to flush/replace clutch fluid?
I also want them to check the slave cylinder while they're down there. Is this an unreasonable request? From a quick check, can they see whether my slave cylinder if failing or not?
Or drive up to Canada and buy Frank a couple of beers.
I'm a big DIY guy, but agree, for <$100, this is kinda a pain, and I've reached a point where I don't really have anyone that wants to spend an hour in the garage with me turning wrenches, and wifey declined when I asked her to pump the clutch 30 times while I lay under the car. So yeah, this is something I'd pay to get done. $450 is an absolute rip off though.
And Frank sounds like a cool guy - that hourly rate is pretty decent.
I really need to have the clutch flushed/bleed again. It's been ~3 years/30K since I last did it. I don't recall exactly, but it was <$100, and I brought my own fluid.
And yeah after watching some videos, I realize that with a lift and another person it shouldn't take ~$400 worth of labor, even if it was super dirty.
It wasn't bad at 3 years, and it isn't bad now. Running Motul RBF600.
I think there is an unrepresentative % of 6MT cars on the internet posting about this problem, because a higher % of people posting on the forums and buying this car are enthusiasts, and more likely to be modding and a part of the community.
That being said, it's a weak link, and a deciding factor, for me, in opting for the extended warranty.
Either my slave or master cylinder went out today.
I was having my clutch fluid replaced and apparently the clutch completely lost pressure and fell to the floor. The mechanic is thinking it's the master cylinder, but I don't recall seeing anything off with it. So I had to see the poor car on a flatbed, strapped down and defenseless.
Weirdly enough, my mechanic is right next door to the Z shop. The tow truck driver let me run over there and I'm looking to get a ZSpeed HD CSC and different master cylinder installed early next week. The Z shop guy kept mentioning the Wilwood HD master cylinder, but I see it's only available for the 350z/g35. Can this part be used for the g37 as well?
