had the wonderful mission yesterday to figure out why my car alarm kept going off...thanks to this forum i just yanked the alarm fuse in my battery. I have a feeling it has something to do with the newly installed battery and sensors because my auto windows had to be reset. Once i did that, the alarm acted up...anyone have any insight into this? i.e. how much it will cost to fix depending on what the problem is...
^^^What offsets are you running there iC? If those are 9.5 +35 you can run a 275, as long as the tires don't run exceptionally wide. My 9.5 +38 on 285s just barely tucks in, but I'm at minimal -1.0 camber. I'm running Continental Extreme Contact DW back there.
From the looks of it you'll have the 15mm extra there to run 275s in back. I don't think I'd run wider than 255s in front just because of that fender edge not being rolled like the rear.
I actually dont know the offsets, its 93owners old wheels. I'll have to check that.
Can i even do 275 in the back with 255 in the front on AWD? I don't think so.. maybe i should just do the 265 square or 255 square, good point about the front fender edge not being rolled though, ill have to check that clearance as well.
Yea I run 285 on my 9.5 +38 rear also... you should look at a square set up for the AWD just because you want the same diameter. A stretched rear won’t be quite the same diameter but it’ll be close.
Edit: there are a couple people on here that stagger their AWD, and square is less important if your rims aren’t (can’t rotate easily). You just need to really focus on diameter.
With AWD I would just go ahead and run 255s all around, you can then do a true four tire rotation for better tire life and have the same mount on all the wheels.
