Sedan Chat Thread
Old May 6, 2016 | 09:02 AM
  #10366
Falker11's Avatar
Falker11
awesome photo Mike. wallpaper worthy
Old May 6, 2016 | 09:06 AM
  #10367
Mik3G37S's Avatar
Mik3G37S
Thanks! oh yeah it already is my wallpaper and my face book cover picture, I hope it makes a cover of a tuner magazine lol
Old May 6, 2016 | 10:19 AM
  #10368
pledes23's Avatar
pledes23
Just picked these up for a crack head price, and a buddy of mine worked his magic on restoring the lens. I think they came out pretty good.
Old May 6, 2016 | 11:25 AM
  #10369
Gregor12's Avatar
Gregor12
Mass air flow sensor does not sense air velocity. It measures the amount of voltage necessary to maintain a given temperature of the hot wire, which is determined by, well, mass flow past the wire. Speed/density systems like those fitted in Hondas use velocity and manifold absolute pressure (MAP) as the primary measuring device. While the G does calculate MAP, it's used as a tweak to what's sensed by the hot wire.
The larger MAF does require new/modified ECU fuel maps so the computer can determine the proper fuel requirement for the new voltage range. Air velocity doesn't figure in for the G air flow sensor. It's common on turboed SR20s to use Mustang Cobra MAFs since they can measure larger masses of air than the stockers. They both use the same voltage range (1-5V?) but the MAF diameter determines what 1V represents in air mass flowing past the hot wire.
Thank you for correcting me. I got that info from AEM on the intakes so figured it was safe to spread lol I understand map and maf and the whole process of change in temperature to voltage. From what I understood, the MAF outputs voltage based on the "cooling" of the hot wire. If you just enlarge the diameter. Air will move slower through the piping and not cool the Hotwire as much as before. That's why it shorts it on fuel right? And I'm talking about a larger piping diameter over stock. Sorry to clutter the thread. Just PM me lol
Old May 6, 2016 | 11:59 AM
  #10370
ColumbiaSkinny's Avatar
ColumbiaSkinny
Just thought i'd post this up if anyone is interested. I've read sometimes when posters are looking or asking about Y pipes. This may have already been posted in another thread so apologizes if i'm late to the party ....
The ISR Performance 370z / G37 Y-pipe utilizes 2.75" stainless steel piping along with bellowed flex sections running from the 2 bolt catalytic converter flanges back to the high performance velocity merge. The Y pipe then steps to 3" stainless piping coming out of the velocity merge to the rear 3" exhaust flange. The Y pipe also features an integrated dimpled gusset plate tying the two individual runners together for increased strength and rigidity.
ISR Performance Exhaust Y-Pipe - Nissan 370z / G37 - Enjuku Racing Parts, LLC
Old May 6, 2016 | 12:12 PM
  #10371
SonicVQ's Avatar
SonicVQ
Our hot-wire MAFs sample a small portion of the air flow and calculates the total airflow. If the MAF pipe is larger at the MAF it will under report the actual air flow, and you will run much leaner, like the 15.5:1 mentioned earlier.
The insert restores the pipe diameter at the MAF back to stock.
Without the insert, a calibration (aka "tune") will be required where the MAF function table (MAF voltage vs airflow) will be updated for the new intake.
Old May 6, 2016 | 01:06 PM
  #10372
SonicVQ's Avatar
SonicVQ
Wow, it has a 3" outlet. Don't most x-pipes have 2 1/4 - 2 1/2?
Old May 6, 2016 | 01:14 PM
  #10373
MaQG37's Avatar
MaQG37
Pretty much every Y-pipe available today has the same outlet. The only company that did a 2.25, was Budget and they are long gone.
Old May 6, 2016 | 01:28 PM
  #10374
SonicVQ's Avatar
SonicVQ
You learn something everyday
Old May 6, 2016 | 02:26 PM
  #10375
Gregor12's Avatar
Gregor12
So does it under report because of the increase in diameter leading to a slower air flow through the pipe. Im with you on everything you're saying but I'm trying to figure out how the MAF actually "measures" the total air flow lol. The only thing that changes when going to a larger piping is the air will move slower through the pipe, right? It's like putting a 5 inch hose on a vacuum that normally came with a 2.5 inch hose. That's why I'm trying to figure out how the diameter relates to the change.
Or, it's just calibrated to that size piping from factory? They set parameters based on what they see with the oem size piping? You guys are explaining what the maf does. But I'm trying explain what the larger diameter piping does to throw off the MAF.. That's where AEM was talking about slower air moving through the piping at that point and tricking the MAF. Because if the airflow didn't change the MAF would still be correct... Right? This may just be a lost cause. lol
Here's a pic to stay on topic. Front end Friday, post em up. Edit: I though i was in the show off your sedan thread
Old May 6, 2016 | 03:00 PM
  #10376
Gregor12's Avatar
Gregor12
"The larger 76mm unit, when equipped with a conical filter directly on the end of the unit (which leans out the MAF signal by reducing air velocity) needed the “richer†Black calibration tube which increases air velocity across the sensor in order to achieve the same calibration as the other 2 units"
That's where I was saying The larger diameter in piping affects velocity/speed which in return throws off the voltage of the MAF because it will not cool the same. It's measurement is not independent of the airs velocity/speed. Does the MAF measure velocity or speed? No. Does the velocity affect the hot wire setup. Yes. So in the end the larger piping will change the velocity of airflow and lean out the MAF reading. This is because the air is moving slower through the pipe causing a higher wire temperature. The higher temp makes the MAF sensor under estimate the airflow. There's a lot of good reads on this. Every article or experiment lists the same affects. Larger diameter ==> Lower velocity ==> Hotter temp ==> Leaner conditions.
Old May 6, 2016 | 03:11 PM
  #10377
Nico-derm's Avatar
Nico-derm
I would have used "equals" signs instead of "greater than"... other then that I agree completely
Old May 6, 2016 | 03:59 PM
  #10378
Gregor12's Avatar
Gregor12
those are arrows tho.... Lemme fix it
Old May 6, 2016 | 06:05 PM
  #10379
slartibartfast's Avatar
slartibartfast
Wiki's Mass Air Flow article
Old May 6, 2016 | 10:32 PM
  #10380
Gregor12's Avatar
Gregor12
Not a bad read, I get how a MAF sensor works but again I'm not just asking about the MAF. I I was talking about how a larger diameter affects the flow and reading. That write up includes nothing about changing mounting locations or pipe diameter. Check this link out as well. Thanks for opening my eyes to some stuff I didn't know
http://www.cnlperformance.com/MAF_info.php?section=15
