Sedan Chat Thread
Old Feb 24, 2016 | 03:39 PM
  #9316
4DRZ's Avatar
4DRZ
Originally Posted by xpcgamer
Just added 5 turns to each corner on my Coil's. Dropped off at the alignment shop. Lets see how it rides this afternoon. Hopefully no more scraping on the damn Speed Bumps!
Yes, hopefully no more scraping. That sucks. I only had that happen once and it was on a short speed bump. I did not even see it because it was short and unpainted and in the middle of the back lot of a building. Heard what sounded like the midpipe scrape. Not a good sound
Old Feb 24, 2016 | 05:47 PM
  #9317
MaQG37's Avatar
MaQG37
I'm running resonated test pipes to my Invidia Q300 and things are still a bit too quiet for me. Any of you fellas got a suggestion to add a little more noise without introducing a whole lot of drone? I'd like to keep my Invidia mufflers because of the look. I'm thinking of deleting the resonators, or adding in shorter resonators.
Old Feb 24, 2016 | 05:49 PM
  #9318
Originally Posted by MaQG37
I'm running resonated test pipes to my Invidia Q300 and things are still a bit too quiet for me. Any of you fellas got a suggestion to add a little more noise with introducing a whole lot of drone? I'd like to keep my Invidia mufflers because of the look. I'm thinking of deleting the resonators, or adding in shorter resonators.
Do you still have the OEM cats? (You need a sig-line, buddy.)
Old Feb 24, 2016 | 05:54 PM
  #9319
MaQG37's Avatar
MaQG37
No , I am running resonated test pipes.
Old Feb 24, 2016 | 06:06 PM
  #9320
RTP, R2C and an Invidia CBE... and it's still not loud enough?
You know, I believe getting your car tuned can change the tonal quality of your car/exhaust.
Old Feb 24, 2016 | 06:18 PM
  #9321
MaQG37's Avatar
MaQG37
I think you are underestimating the resonators and mufflers on the Q300. Have you heard one in person?
I plan on getting a tune, but still have some mods I'd like to do before it. Z1 UIM, pulleys, and AAM CAI.
Old Feb 24, 2016 | 06:30 PM
  #9322
That's likely. Pretty quiet stuff, eh?
I think the answer is probably yes, after the last two Sedan meet-ups. But not in any way that was notable. The only exhausts that really made an impression on me were ARK and Fast Intentions.
Oh I absolutely figure you'd be getting tuned someday. We're on similar paths.
Old Feb 24, 2016 | 06:40 PM
  #9323
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Finally got around to making a second grounding kit out of much thicker ofc cable. No more cca yay! The colour is slightly darker than the previous cable, but still within a 10% shade of the rest of the engine bay. Can't wait to install it this weekend.
Old Feb 24, 2016 | 07:33 PM
  #9324
2GoRNot2G's Avatar
2GoRNot2G
Huh? Resonated Test Pipes, and full Invidia exhaust with resonated mid-pipe and it's too quiet?!?! I scrapped this same basic set-up except with Berk HFC's after just a few months because it way definitely too loud for my tastes with a little too much drone at around 3K RPM's on the freeway. Berk HFC's with the OEM mid-pipe and Tanabe axle back was just about perfect for me, but now I'm running the OEM CATs too and its a bit too quiet for my taste.
Might I suggest pulling the cotton ***** out of your ears before driving your car next time.
Old Feb 24, 2016 | 07:39 PM
  #9325
2GoRNot2G's Avatar
2GoRNot2G
Is removal of OEM intakes a pain? Any pics/DIY for access to turn signals from under the hood?
I ask because I've really wanted to install switchback turn signals, but kept delaying since going through wheel well seems pretty tough, and neighbors will yell at me if I take a wheel off...
STown, you can get "access" to the turn-signal portion of the headlight with the air boxes out, but it's still not easy. Plus, if your installing switchbacks you'll need a place to mount the resistors and switchback modules, so it's much easier to just remove the inner fender liner and do everything through the fender-well... only takes about 30 minutes a side.
Old Feb 24, 2016 | 07:43 PM
  #9326
2GoRNot2G's Avatar
2GoRNot2G
Looks great, Hexotic! You must have some great soldering skills to put that together! I was an installer for custom car audio for years, so I know it can take time (and a decent soldering iron) to solder heavy gauge wire like that. Great job!
Old Feb 24, 2016 | 08:03 PM
  #9327
MaQG37's Avatar
MaQG37
I have the updated Y which is quieter. For comparison, a FI with 12 inch resonators and OEM cats is louder.
Old Feb 24, 2016 | 08:23 PM
  #9328
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Some good flux, patience and a wire clamp lol. Then heat shrink and purty wires are done I heat the stripped wire with a small torch too (kind of like when you solder copper water pipes)
Leftover skills from my past. I got into university for robotics and electrical engineering, and ended up going to university for art and design, following my passion. Best decision I have ever made. Now the skills come in handy from time to time
Old Feb 24, 2016 | 09:36 PM
  #9329
Probably nailed the area right around the braided flex pipes at the end of the Y pipes, those things take a beating.
Old Feb 24, 2016 | 11:51 PM
  #9330
4DRZ's Avatar
4DRZ
I think it was actually the flange at the back of the Y pipe. That part hangs just a bit lower on the Stillen exhaust, but it is pretty beefy. The last time I had the car in the air I could not even see where it bottomed out.
