Sedan Chat Thread
Old Feb 7, 2016 | 11:48 PM
  #9121
lobuzz311's Avatar
lobuzz311
G37 Sedan *Chat Thread*
Get ready to find shards of metal in your skin for the next few weeks!
It's not too bad, but you'll go through a good number of cutting bits / wheels.
Old Feb 7, 2016 | 11:59 PM
  #9122
ZahyMatar's Avatar
ZahyMatar
It's not too bad, but you'll go through a good number of cutting buts / wheels.
I just hope I don't screw it up. I wish I didn't even need to use them but I'd rather deal with this than have to deal with premature tire wear.
Old Feb 8, 2016 | 12:04 AM
  #9123
Use those cutting wafer/wheels that I posted in your build thread, you'll be ok
Old Feb 8, 2016 | 10:45 AM
  #9124
VIVID's Avatar
VIVID
Pyroclastic Flow
So newt, when does the Broncos avatar come down? LOL
I miss crazy Joe Divola...
(congrats, BTW)
Sean
Old Feb 8, 2016 | 10:49 AM
  #9125
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
Speaking of the Broncos. They're paying for my fluid changes. Won $500 last night.
Old Feb 8, 2016 | 02:36 PM
  #9126
Lol, I'm taking down the Avatar when this buzz from their first SB victory since 1988 wears off. Not sure when that will be
Old Feb 8, 2016 | 03:32 PM
  #9127
2GoRNot2G's Avatar
2GoRNot2G
Originally Posted by xpcgamer
Finally replaced factory battery. It only had 300CCA's. Lost two plastic push pins in the process. Dammit!
Just curious, but what year is your car? My factory battery finally crapped out last year. Ended up replacing it with a Die Hard Platinum Group 35 with 850 CCA! The original lasted almost 7 years, so I'll be happy if the new one lasts even close to that long.
FYI.. You can get 25 of those 8mm push pin clips on eBay for $4.29 including shipping... local supplier here in SoCal.
http://www.ebay.com/itm/25-BUMPER-PUSH-CLIPS-FASTENER-RIVET-8mm-01553-09321-For-NISSAN-INFINITI-/172089472729?vxp=mtr
Old Feb 8, 2016 | 03:44 PM
  #9128
Arrogant's Avatar
Arrogant
Uhhh, the broncos lost in 88. They won in 98 and 99.
Old Feb 8, 2016 | 04:19 PM
  #9129
2GoRNot2G's Avatar
2GoRNot2G
Just ordered two pairs of SPC 72265 rear toe/camber bolts to pair up with my Swift springs. Hopefully the hobby shop on base has either a dremel or some other form of rotary cutting tool. Should be an interesting experience.
Good call on getting these, ZM. The install isn't really that difficult, but it is time consuming. It can even be done with a round hand file, but it would probably take hours to do all of the holes. Just make sure you have a few extra good cutting or grinding bits for the Dremel, as one bit definitely won't cut it (pun intended). Here are a few pics from when I did mine. Good luck.
Before:
During:
After:
Old Feb 8, 2016 | 04:53 PM
  #9130
ZahyMatar's Avatar
ZahyMatar
Before:
During:
After:
Did you just get the toe bolts? Or camber bolts as well?
Old Feb 8, 2016 | 11:23 PM
  #9131
See, I told you I was buzzed.
Old Feb 9, 2016 | 11:16 PM
  #9132
4DRZ's Avatar
4DRZ
Originally Posted by iCrap
Is that such a good idea though? My friend had (keyword, had) an e46 M3 which was only driven a little bit during the summer months, and thats it. They did the oil change like once every year and a half, and about 2 years ago the engine blew up. maybe it wasn't using synthetic though, IDK.
Sorry to hear about your friend's M3, but what blew in the engine that was caused by the oil? I had an E46 M3 and the issue with those engines is the Vanos system. Yes, the scheduled oil change interval is roughly once a year, but most E46 M3 owners know to change it at least every 6 months. I still think he would have been ok with that $16/quart Castrol oil they recommend.
Old Feb 9, 2016 | 11:59 PM
  #9133
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
A lot of BMW's have serious cooling issues, even the M3, on a hot summer day... oil temps skyrocket...
Old Feb 10, 2016 | 12:03 AM
  #9134
ZahyMatar's Avatar
ZahyMatar
Don't forget about electrical issues
Old Feb 10, 2016 | 12:40 AM
  #9135
2GoRNot2G's Avatar
2GoRNot2G
I actually did the test fit for the Ichiba rear camber arms for our cars years ago, so I ended up with a free pair of those, so I only had to install the SPC bolts to correct the toe.
Evasive Motorsports | PH: 626.336.3400 Mon-Fri, 9am-6pm PST: ICHIBA Camber Arm / Toe Bolt Kit (Rear) - Nissan 350Z, 370Z / Infiniti G35, G37, M35, M45
