Sedan Chat Thread
Old Jun 22, 2015 | 01:15 PM
  #7006
RexHavoc's Avatar
RexHavoc
True, but not by choice. It's the configuration that came from Vossen, and I'm none too happy with it, either. But I need the shorter stem for caliper clearance, since the valve is halfway deep inside the rim.
It's a cool looking design, having a deep lip. But kind of impractical. And a huge PITA to both clean and attach an air hose. I can't stress enough what a PITA that deep inner lip is.
/firstworld
I'm wondering how different that will be on my Rays. In my situation I'll be running them just to get the neo valve caps lower and more onto the wheel itself with the adapters. I think it will work. I hope.
Old Jun 22, 2015 | 01:24 PM
  #7007
Old Jun 22, 2015 | 02:06 PM
  #7008
nishfish871's Avatar
nishfish871
Thanks Rochester, I ended up ordering the non-tpms Hawkshead stubby seeing as our TPMS system is completely dumb. The WedsSport valve stem is a whopping $15 EACH. Luckily I don't have a problem with the deep inner lip. I just wanted a metal shorty valve stem that was affordable. $26 for all 4, I can live with that
Old Jun 22, 2015 | 04:05 PM
  #7009
RexHavoc's Avatar
RexHavoc
Not stubby enough dammit.
Should work okay if I go grey. What's another couple hundred dollars?
Old Jun 22, 2015 | 04:13 PM
  #7010
ttv36's Avatar
ttv36
Race, repair, repeat.
Had an alignment done about 3 months ago, -2 camber and toe again in spec.
I would get the alignment rechecked, I think your toe is probably off. It is possible the last tech didn't tighten the toe bolts enough when they adjusted it.
But I think lasting 10 months is pretty good, I usually have to change my rear tires every 6-8 months or so.
Edit:
Here are some weekend shenanigans
Old Jun 22, 2015 | 10:31 PM
  #7011
Mik3G37S's Avatar
Mik3G37S
If anybody ever considered installing a KP technologies fog light module, I myself advise not to, the word is some have successfully installed it but I'm not one of those people, It works but I'm stuck with a bigger problem now because of that, windows are stuck open and won't budge up nor down and also noticed the issue that I've heard of before that when the fogs are off and I use left turn signal, the foglights go on...
I'm stuck with no car till this gets figured out while my car sits at my buddy's garage
Old Jun 23, 2015 | 06:36 AM
  #7012
Lego_Maniac's Avatar
Lego_Maniac
That sucks. My wife got me one as a gift years ago, but I never installed it. Instructions seemed.....complicated. At $50, you would think it would be more commonly used. Maybe there is a reason for that...
Old Jun 23, 2015 | 07:38 AM
  #7013
Daddy Fat Sacs's Avatar
Daddy Fat Sacs
well alignement was done this past sun, ill post the new specs now. and no offesnse but 5k miles and 10 months of use for mild driving is completely unacceptable. Not like i'm running TT 500+whp...then I could get there
Old Jun 23, 2015 | 08:14 AM
  #7014
That's disappointing. Unless I'm mistaken, all you wanted to do was turn on the fog lights irrespective of the headlights, right? Seems you got a world of complications because of this thing.
Similarly, but way less severe, if you use those courtesy light projectors in the door lights, and one of the front doors are open, the only way you can open the trunk is with the release button on the dash. The fob and the release button on the trunk fail to function. Close the door, and everything works again.
Weird electronics, man. Very touchy.
Old Jun 23, 2015 | 10:12 AM
  #7015
RexHavoc's Avatar
RexHavoc
I thought you decided not to use them because of the potential for issues?
Old Jun 23, 2015 | 10:23 AM
  #7016
ttv36's Avatar
ttv36
How was the toe in the 'before' alignment section? I was anecdotally speaking on my previous 5 years of ownership with stock power levels where my commute was about 50 miles a day/5 days a week so about 6-8k miles. I guess in this situation mileage is more important than time? I understand your frustration though since the tires you ran did cost a pretty penny.
I haven't made it 6 months with TT yet, but I did have to replace my hankook tires last month that I bought last year around this time - they probably lasted that long because the car was sitting on a lift for 5+ months. I definitely won't be getting another set of those tires, but they were the cheapest at the time and I foresaw that I would have to replace them after the build. I have been told that PSS wear out quite fast from others so I decided not to get them and went with Continental DW tires for the street and am saving for a set of 18s for the track.
Old Jun 23, 2015 | 10:55 AM
  #7017
ChinkyChoy's Avatar
ChinkyChoy
one of the reasons why I never mess with electrical
Old Jun 24, 2015 | 09:34 AM
  #7018
Daddy Fat Sacs
well when I bout my rims/tires last Oct I had the dealership install everything along with an alignment. At that time I was running -2.2 camber and toe was within spec. Dont recall exact figure but all 4 tires were "green". I purchased the lifetime alignment from Firestone and had the car aligned again back in March I believe....and again was at -2.2 camber and again toe on all 4 corner was within spec. The roads arent really that harsh around here with the exception of a few hwys and my daily work commute is about a 10 mile round trip. The tires were only tracked once back in Nov and that was the 1/4 mile. So im not sure what went wrong where these past few months as my previous specs on the sheet was showing specs were outta whack, but to have both tires wear down the exact way within a 5k mile timeframe is just crazy. Trust me if I was abusing them alot then I could understand, but that wasnt the case here.
This time I went with some Dunlop sp sport maxx gt’s, so far so good, they grip the road very well imo. Guess time will only tell, but I do plan on getting an alignment about every 3 months now just see if the problem continues
Old Jun 24, 2015 | 09:41 AM
  #7019
ChinkyChoy's Avatar
ChinkyChoy
I got my alignment done a couple weeks ago and my toe was red in all four corners and the last time I got an alignment was over a year ago. my tires didn't even come close to looking like yours and I m running more camber than you
Old Jun 24, 2015 | 11:21 AM
  #7020
ttv36's Avatar
ttv36
When you say toe was in green are you talking about the "before" or "after" toe? I am asking if you know the "before" toe numbers not the "after" as the "before" tells you how much your alignment changed since the last time you had the car aligned. If your "before" values were in the green each time then it is quite puzzling as you say.
Hopefully you get better results with your dunlops! I find tires to be quite tricky as everyone has different experiences with any one brand/model and if we have a bad experience we can become jaded. Not to mention the fact that we all have our own different driving styles, suspension/alignment settings, and even within every batch of tires performance/durability could be different which complicates things even further.
