Sedan Chat Thread
Old May 21, 2014 | 10:59 AM
  #2731
Diode Dynamics's Avatar
Diode Dynamics
Originally Posted by connoisseurr
The switchback color is VERY close but is off slightly. Still looks awesome at night though. The LED turn signals are definitley my favorite. The crisp on/off just looks rich. Next LED project will DEFINITELY be LED mirror caps
I'll need to break out the DSLR and shoot it with some altered shutter settings to really capture the lights but here's what iPhone 5S is capable of LOL. I will probably just get a video of the switch backs and ambers working - seems more appropriate to show it that way anyhow.
Admittedly our switchbacks are close to a 6000K color, so they won't match OEM HID's perfectly, but either way it's a big improvement over the factory amber. Really modernizes the front end IMO.
One of my favorite lighting upgrades
Nick C.
Old May 21, 2014 | 11:05 AM
  #2732
connoisseurr's Avatar
connoisseurr
Nick C.
I couldn't agree more - I love how it looks now (minus the Amber city LED I have yet to replace.
I used 50W 6ohm resistors all the way around. After doing some reading, I noticed some folks did 50w 3ohm resistors all the way around. Nick, what's your recommendation?
Old May 21, 2014 | 11:17 AM
  #2733
Diode Dynamics
We recommend the 6ohm 50 watt resistors. It's fairly universal, but their size and heat sink does a great job dissipating heat
As long as you don't try to use 1 big resistor instead of two 6ohm 50 watts you'll be ok. Some companies will try to sell you on using 1 big one, but this centralizes the heat to one resistor rather than spreading it out.
That's going to increase the chances of melting something or worse
Use SMD style LEDs to match the switchbacks also
Here's a G37 member's comparison photos (Big thanks to this member)
Nick C.
Old May 21, 2014 | 12:03 PM
  #2734
ANMVQ's Avatar
ANMVQ
What bulbs are those? I have LED fog light bulbs from you and mine don't look like that
That's the look I wanted to match my 8k HIDS from you. I have a 09 Sedan
Old May 21, 2014 | 12:05 PM
  #2735
Diode Dynamics
These are SMD 194 sized bulbs, and again, they will be a 6K color
Still an improvement over the ugly factory bulbs, but they aren't a perfect match with 8000K
If you need more information about them, give us a call: (314) 205-3033
I don't want to hijack the chat thread
Nick C.
Old May 21, 2014 | 01:52 PM
  #2736
connoisseurr
Thats what I am using for each LED (1 for each switchback, two up front, and 1 for each rear turn signal LED, two in back = total of four 6ohm 50watt resistors).
Seems like everything is normal - I left the turn signals on for 2 minutes and the resistors warmed up quite a bit. I protected the trunk liner with some aluminum ducting tape that will help whick away the heat from directly touching the trunk liner itself. Fronts were a piece of cake and out of the way completely.
Old May 21, 2014 | 05:54 PM
  #2737
Pulled into KOHLS today, to do some shopping before vacation. Clutch pedal was feeling weird. Drove around the parking lot to get a feel for what was going on, and the pedal started fading fast. Then it just dropped right to the floor.
Seriously. Clutch pedal just dumped, limp like my d1ck watching sumo wrestling.
Coasted into a parking spot. Called the Infiniti dealership, and they sent out a flat-bed. I suspect the clutch cylinder blew, but IDK really. All I know is I got real, real lucky that I was in a parking lot, and not on the highway.
Or somewhere in the Pennsylvania woods on a weekend.
Old May 21, 2014 | 08:10 PM
  #2738
connoisseurr
Pulled into KOHLS today, to do some shopping before vacation. Clutch pedal was feeling weird. Drove around the parking lot to get a feel for what was going on, and the pedal started fading fast. Then it just dropped right to the floor. Seriously. Clutch pedal just dumped, limp like my d1ck watching sumo wrestling. Coasted into a parking spot. Called the Infiniti dealership, and they sent out a flat-bed. I suspect the clutch cylinder blew, but IDK really. All I know is I got real, real lucky that I was in a parking lot, and not on the highway. Or somewhere in the Pennsylvania woods on a weekend.
Same damn thing happened to me in my Acura. Was exiting the parking garage at work and the clutch just dumped. Acura replaced a clutch cylinder and gave me a brand new clutch - which was above and beyond what they needed to provide.
Old May 21, 2014 | 08:14 PM
  #2739
connoisseurr
Also I'm putting this out there for everyone. My buddy's performance shop has a full set of Akebono calipers for sale. They are being rebuilt and will be powder coated any color of your choice. I don't have a price for them yet but that can easily be acquired.
So, If you're looking for a new set of calipers, here is your ticket. Plus, you'll be able to get them coated any color of your choice. PM me If you're interested and I'll put you in touch with the shop.
  #2740
Lego_Maniac's Avatar
Lego_Maniac
Isn't this a somewhat common problem on these cars?
Cue dueling banjos
Old May 22, 2014 | 05:09 AM
  #2741
'11G37S's Avatar
'11G37S
A 1/4 mile @ a time
Man... that sucks... glad you were able to pull into a parking spot safely. Are you going to have it taken to Circle Infiniti and request loaner car #10?
Old May 22, 2014 | 05:54 AM
  #2742
Clutch failure is endemic on the G/Z cars? What?
Good old #10.
They didn't have any loaners for an unscheduled service. But they did give me a ride home. Service is pretty good there, but it's also obvious that out of the 9 brands they sell, the upscale ones get preference (Infiniti, Lexus, Maserati).
Old May 22, 2014 | 07:10 AM
  #2743
Lego_Maniac
I dunno about endemic, but I've seen enough posted about it to say the clutch slave cylinder isn't an uncommon issue. Good summary post:
https://www.myg37.com/forums/engine-...ound-info.html
Old May 22, 2014 | 08:34 AM
  #2744
WhiteG_6MT's Avatar
WhiteG_6MT
My clutch stuck to the floor about a year ago. After attempting to fix myself by draining, replacing fluid, then bleeding (used a generic DOT4 fluid) it lost pressure again within a half hour.
The dealership fixed it under warranty. They told me that the fluid had boiled and that this was a known issue due to routing of the clutch fluid line near the exhaust or some such.
The fix, and it has fixed it, was for the dealer to use a special Nissan Racing DOT4 fluid that would resist the heat -- ie not boil and aerate.
No problems with the clutch since.
However, I did start noticing a grind going into 5th gear a while back.
I brought the car to the dealer again last Tuesday. They called me on Wednesday and said "you need a new transmission".
So, I got a new trans, a new slave cylinder, and a new throwout bearing installed at no cost.
The new trans shifts like butter compared to the last one.
Anybody who is under warranty and is getting any sort of grinding while shifting should report that immediately IMO and get it resolved before the warranty expires.
The service adviser told me that when they drained the MT fluid from my old trans, that it had a lot of metal shavings in it. I think the 5th gear syncro was starting to disintegrate.
Heads' up MT drivers!
Old May 22, 2014 | 08:54 AM
  #2745
Welcome to the forum. And you're scaring me, man.
I have 9 months left on my 4/40 warranty, but 32 months left on my bank note.
