Sedan Chat Thread
Old Mar 24, 2014 | 12:11 AM
  #2086
connoisseurr's Avatar
connoisseurr
Originally Posted by RexHavoc
Be worth a try for certain. If I had them I'd send you a set. For long trips I still rely in my garmin normally. Maybe I do need the update or maybe I just can't figure out how to work the dang thing over a couple states...
I usually use my phone as well. From what I've noticed, you have to select a different region on the OEM Nav. When I first purchased my G used, it was set to the Northeast Region of the US.
Old Mar 24, 2014 | 12:23 AM
  #2087
RexHavoc's Avatar
RexHavoc
I "think" I tried the other region last time I drove to NJ but it freaked out on me. I'll try it out again for the meet but bring the garmin as a backup.
Old Mar 24, 2014 | 12:52 AM
  #2088
connoisseurr
I haven't even attempted to change my out of the region I'm in so I can't tell if mine will freak out or not. Using my phone is definitely easier as well, because I'm usually listening to something on there and the GPS directions come through the speakers.
Old Mar 24, 2014 | 09:09 AM
  #2089
stiizy's Avatar
stiizy
So I was driving on the highway and my front left axle snaps. I was doing about 75, nothing crazy though. I'm here at infiniti now, mad they had no loaners. Stuck in the waiting room at Fette.
Old Mar 24, 2014 | 09:15 AM
  #2090
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
You had an AXLE snap? How did it happen? Was it actually the axle, or a control arm or something? I'm guessing you're okay, since you're at Infiniti and not a Hospital.
Old Mar 24, 2014 | 09:46 AM
  #2091
stiizy's Avatar
stiizy
I was just cruising doing about and the axle snapped by the bolts, ripping my power steering line and a few wires. Not covered under warranty.
Old Mar 24, 2014 | 10:25 AM
  #2092
Wow, glad you're OK, any body damage done? Sure seems like something defective was involved, I would look into this as far as warranty is concerned. Is your car stock or do you have suspension/wheel mods?
Old Mar 24, 2014 | 10:28 AM
  #2093
stiizy's Avatar
stiizy
Thanks, no body damage. Car isn't lowered yet and no wheels. They say the axles aren't infiniti parts so they're not going to warranty it. I can see this being expensive. They're working an estimate now, I'll let you guys know exactly what it is.
Old Mar 24, 2014 | 10:37 AM
  #2094
Huh?
You aren't the original owner?
Old Mar 24, 2014 | 10:39 AM
  #2095
stiizy's Avatar
stiizy
Huh?
No I'm not, I just got the car in December, I'm the second owner.
Old Mar 24, 2014 | 11:17 AM
  #2096
kOrE's Avatar
kOrE
Oooh, so a defective after-market axle. . . . that thing is blatantly defective. That sucks. Do you have any of the service receipts from the prior owner?-
Old Mar 24, 2014 | 11:18 AM
  #2097
stiizy's Avatar
stiizy
So it needs a new axle, the power steering harness needs to be repaired and the bolts need replacing. They want $1800. This **** is crazy...
Old Mar 24, 2014 | 11:28 AM
  #2098
stiizy's Avatar
stiizy
I bought it from a used car dealership. The last time the car was serviced was at 12 miles for pre-delivery inspection. Now it has 47k on it.
Old Mar 24, 2014 | 11:35 AM
  #2099
Kind of forces yourself to ask the unanswerable question: what originally happened to the car that called for the axle to be replaced? And what else was worked on during that repair, using non-OEM parts?
Damn. This is one of those expensive moments that forces you to make a bigger decision. Either you sell the car after the axle repair job, which might not turn out so well for you. Or you plan on keeping the car for enough years that the repair costs, and resale hit, are both absorbed by long-term ownership. Either way, you have to get the car fixed, which nails you out of pocket nearly $2000.
Tough day for you, man. Cars are a money pit, that's for sure.
Old Mar 24, 2014 | 11:39 AM
  #2100
kOrE's Avatar
kOrE
Yea, that's rough man! Good luck.
