Sedan Chat Thread
Old Aug 9, 2014 | 03:00 AM
  #3586
dragion's Avatar
dragion
Yeah man, I'm liking it. Just wrote up a quick review in my progress thread.
Nice John...I'm liking it!
Old Aug 9, 2014 | 10:25 AM
  #3587
nishfish871's Avatar
nishfish871
That's what I thought. Anniversary Edition, too, IIRC.
Basically, what I was saying is that there are no Sport Sways, per se. Just AWD Sways and RWD Sways. But it certainly helps market a FS thread to refer to them as Sport Sways, and not entirely inaccurate either.
Oh I thought the G37S had different sways than a regular rwd G37.
Old Aug 9, 2014 | 10:44 AM
  #3588
I did, too. Until I sold my Sport sways to Brad, and he measured them against his identical Journey sways, then assessed the total absence of changes after installation.
Oops.
It seems the "sport tuned" suspension on the RWD Sedan Sport Package is simply a different set of struts. (Granted, the close-ratio steering, VLSD and BBK are welcome upgrades, but still...)
Old Aug 9, 2014 | 01:53 PM
  #3589
'11G37S's Avatar
'11G37S
A 1/4 mile @ a time
Oops.
Just another thing about Infiniti that doesn't make sense to me. Even the Camry has sport sways. When my mechanic and I were under my car checking torque on my exhaust we were looking at various items under the car, for instance there is no AC drain outside of the body of the car, under engineered. The rear bushings are all one piece casted steel, over engineered. Then the whole debocal with the xS receiving basically nothing but the appearance package while the coupe and vert at least get the BBK... I don't get it.
Old Aug 9, 2014 | 08:39 PM
  #3590
Lego_Maniac's Avatar
Lego_Maniac
Operation Koni + Swife Installation = complete
I started at about 11, and I finished at 6. Yeah, 7 hours. But I had several interruptions, my sister-in-law and her 3 kids, my father/mother in-law and a surprise visit from the sheriff
That 7 hour total does at least include getting the car jacked up and cleaning up everything and putting my tools away
I could do it a lot faster if I was doing it again.
Anyway, no real problems. The bolt that everyone seems to have problems with only caused me issues on the passenger side. I supported the A-Arm with my jack on the driver side--other wise you're just torquing the suspension down--and it came right off. Not on the passenger side. Used a 6 point wrench and a dead blow hammer. Problem solved. You probably don't want to do this job with 12 point sockets/wrenches, 6 points are a must.
I drove a couple laps around my neighborhood and was pleased. No squeaks or any bad noises. Feels tight. Driving impressions tomorrow. Because inlaws.
Old Aug 9, 2014 | 08:49 PM
  #3591
Adam West's Avatar
Adam West
Is the drop lower on the rear than the front?
Old Aug 9, 2014 | 08:54 PM
  #3592
Lego_Maniac
I don't think so, Swift claims 1.2 front, .8 rear (or something like that). I took before measurements, but not after (yet).
Old Aug 9, 2014 | 09:02 PM
  #3593
That's the claim. It will still look uneven front to back, but not so much as to make a big deal about it. Looks about what I'd expect in your picture. If you correct for the shadow in the pic, you can see the gap differences.
After a few months, I've got all kinds of creaks and groans when moving the car around the driveway and low speed over gutters and whatnot. It's annoying, but I'm accepting it until the day comes the entire suspension is swapped for CO's. Couple of years, at least.
So... alignment, then spacers?
Old Aug 9, 2014 | 09:16 PM
  #3594
Lego_Maniac
Yeah, alignment next, then either +0 tires or maybe spacers. Tires didn't seem to tuck in as much as I thought they would. I'm going to need tires soon.....
Old Aug 9, 2014 | 11:29 PM
  #3595
Looking nice Chris, but some more questions need to be answered~
How many Sammies got destroyed and what's the skinny on the visit from the Sheriff???
Old Aug 9, 2014 | 11:37 PM
  #3596
Here's a question my wee little brain can't process: when dropped, is the camber spec affected by how much sidewall is available to the tire? In other words, when dropped on OEM 18's, could the camber potentially be more in line with specs than if it were dropped with the identical hardware, but on 19's or 20's?
My rears are at -2.1* and -2.2*. I wonder if Lego will fair better?
Old Aug 10, 2014 | 12:16 AM
  #3597
MylilG's Avatar
MylilG
I believe it won't matter if you have the same hardware or not. correct me if I'm wrong but I'm pretty sure if you modify anything in the suspension (lowering/raising) that it will still affect the camber and toe. Rim diameter shouldn't make anything any different as long as the tire/rim combo overall diameter is the same or close to stock. Now, width of the rim will however affect it as you will have more or less area to touch the ground with.I hope you understand what I mean.
Old Aug 10, 2014 | 12:50 AM
  #3598
Yep, camber won't be affected by your sidewalls, it's just the geometry of your suspension that's changing as you go lower.
Old Aug 10, 2014 | 12:53 AM
  #3599
AroundTheG37's Avatar
AroundTheG37
I got my rears to 1.8 which I feel was a win........
Old Aug 10, 2014 | 08:33 AM
  #3600
OK. Then how come AroundTheG37 and I have a 0.3* and 0.4* difference in our rear camber alignment? We're both dropped on Swifts, each with a RWD Sport Sedan, and each with 19" wheels?
BTW, AroundTheG37... are you considering that ES bushing mod to lift the rears back up 1/2", or have you finally come to peace with the setup? Every now and then, I look at the rears and think I should do that. CO's are still 3 years out on my schedule.
