Clunking in cold weather!
Alright folks, here's my problem. When the weather began to turn cold a few weeks ago, I started to hear a clunking noise coming from my front suspension. I assumed that because the temp increased over the next couple of weeks, and the bolts securing my strut brace had backed off proper torque, that was the cause of the clunking since the noise was reduced. I checked the torque of my sways also, but they were just fine. Now it's cold again and the clunking has returned. Any suggestions before I would have to take the car back to stock and roll it to the dealer?
G-DOG
I've had similar problems as you described in previous cars I owned with aftermarket sway bars. The problem may be the grease you're using. If the grease hardens significantly in cold weather you can get the clunking noise you described. I only use Prothane grease now on my sway bar bushings and have had no problems since then.
I have the same problem. It is coming from both front wheels. Happens in the morning on the way into work (very cold out) and when the wheel goes into a dip. Once the wheel hits the bottom of the dip and the car drops as the wheel starts to climb back up, that is when the clunk sound happens. Almost like the shocks are bottoming out. I took it into the local Infiniti dealer and they checked it out and couldn't find anything wrong. We even went on a test drive and of course, I couldn't get the car to reproduce the issue. So, will have to keep an eye on it. Let me know if you find a source of the issue.
G-DOG
A simple test is to put a sample of grease in your freezer overnight and see how much the cold affects is viscosity. If it get significantly harder, its probably not something you want to use on sway bar bushings.
i have the same issue after installing bc racing coils on all wheels, and its worst in cold weather. the only time that i dont really hear it is in wet/humid weather. ive been searching for a solution for a while and really didnt find anything, i hope there will be a solution here, it is really annoying and i really wanna get rid of this issue.
Raffay Khan
Intake and Exhaust
Sep 14, 2015 10:47 PM
