Service Bulletin ITB10-075 Detail Compatibility Info
Old Apr 23, 2011 | 03:55 PM
clx's Avatar
clx
Just took my 2011 G37 RWD to service and asked the dealer to perform the ITB10-075 reprogram since I've been experiencing not-so-smooth transmission in the first and second gear. However, the dealer informed me that my car's VIN is not listed in the ITB and gave me the first page of the official ITB document.
You can see the scan of the document attached. Just thought I would share this in case anyone wondering if their car can be reprogrammed with ITB10-075.
Did anyone actually get their car reprogrammed even if your VIN doesn't fall within the range specified by the ITB?
Attached Thumbnails Service Bulletin ITB10-075 Detail Compatibility Info-infinitiservicebulletin_000.jpg
Old Apr 23, 2011 | 04:41 PM
Modme's Avatar
Modme
If the vin doesnt fall under the range specified by the ITB, it usually means that your car already has the newest program.
Old Apr 25, 2011 | 02:54 PM
bitNine's Avatar
bitNine
Looks like mine doesn't fall under it, and I still get that awful 2-1 jerk.
Old Apr 25, 2011 | 03:30 PM
poolshark01's Avatar
poolshark01
Mine falls within. Has anyone confirmed that this actually corrects the problem? The only one mentioned that i have noticed is the 2nd to 1st hard shift particularly in "DS" mode.
Old Apr 26, 2011 | 01:29 AM
clx's Avatar
clx
I actually experience 1-2 shift vibration and hesitation to take off from stop from time to time. There is also one instance that I did a fast break on freeway @ 60 mph, the down shift didn't response right and the RPM went crazy for a second. Looks like the original ITB didn't specify the range of VINs, and this is the updated version doc.
Old Apr 26, 2011 | 08:48 AM
hollywhip's Avatar
hollywhip
I noticed on the ITM that after the AP# they all have BM# Mine has a AM# what the heck does that mean. I don't need the re-program? Or my car was made in Amsterdam...!
Old Apr 26, 2011 | 08:55 AM
poolshark01
So i found the other thread about the reprogram and it appears there were some mixed results. Is this new ITB just a revision of the last one in terms of which cars are affected or did they actually change the code that is uploaded? Has anyone had this done very recently?
Old Apr 26, 2011 | 11:26 AM
Mudgen's Avatar
Mudgen
Thanks, clx. This is kind of a shock. I have the 2nd, 4th, and 5th symptoms, but my VIN is above JN*BM403082, so apparently not covered.
First service is scheduled for May, I'm going to ask to have the TSB evaluated against the symptoms anyway. I'm very attuned to the "vibration/shutter" because my '08 Legacy GT had it, was scheduled to have the TC replaced under a TSB when I traded it. I couldn't believe it when the G37x did it, too. Had to drive it a couple thousand miles before I was sure it wasn't my imagination carrying it over from the old car.
The hard downshift is just breathtaking sometimes. First time it happened I thought the thing had just seized up.
Old Apr 26, 2011 | 10:50 PM
tharbemiko's Avatar
tharbemiko
Wow this is quite disappointing :/ My VIN isn't covered but I'm definitely experiencing some rough downshifts (VERY ROUGH 4->3). Regret getting an auto haha
Old Apr 26, 2011 | 11:11 PM
cereal2k's Avatar
cereal2k
Mr. Drop it like it's hot
I've got the slight vibration on starting off and I was figuring I needed some strut brace/front subframe chassis braces. I'll have to check with them and see if my vert is on the list.
37
Oct 17, 2020 11:12 AM
delfinparis
Nov 16, 2015 02:26 PM
Junchao Sun
25
Oct 1, 2015 12:41 PM
BurtoN86
Sep 30, 2015 03:32 AM
MrRiv
Sep 29, 2015 04:59 PM
