Aero Package
Old Dec 30, 2010 | 02:33 PM
Ibanez540r's Avatar
Ibanez540r
Originally Posted by G73xs
HELL NO!!! it's not right. tell him you're supposed to pay the depreciated value of it. It should be around 40%. he's trying to screw you.
Could you elaborate a little so when i throw it in his face I can sound like I know what I'm talking about? I should only pay $40% of the cost of aero kit, how does the depreciation work into an accesory?
Old Dec 30, 2010 | 03:07 PM
Chico's Avatar
Chico
Not necessarily 40% but the depreciated value. If your car has a 62% residual value, then it'll be worth 62% of the MSRP at the end of the lease. So, if the Aero package cost $840 and the residual value at the end of the lease is 62%, then you should pay only 38%, or depreciation. The numbers are only examples. The package is being installed before delivery so it should be included in the lease which will allow you to pay only depreciation and not full value.
Old Jan 2, 2011 | 01:27 AM
salerngo45's Avatar
salerngo45
I bought my aero kit after I purchased the car for much less and installed myself, if ur handy will take you an hour
Old Jan 2, 2011 | 01:51 PM
Ibanez540r's Avatar
Ibanez540r
Does the rear spoiler require drilling into the decklid? The OEM for my accord coupe did, and that was a nervous feeling drilling holes into metal panels of a brand new car lol
Old Jan 3, 2011 | 10:02 AM
LightsOut's Avatar
LightsOut
yes it does^^^
Old Jan 3, 2011 | 11:13 AM
gee wiz's Avatar
gee wiz
FYI: The front chin spoiler and splash guards also require drilling. I agree though, having to drill the rear deck lid is a bit more intimidating. Just measure and dry fit multiple times if you are nervous about it.
Old Jan 3, 2011 | 07:55 PM
salerngo45's Avatar
salerngo45
It came with a template and as long as u line it up it's perfect
Old Jan 3, 2011 | 08:14 PM
rks's Avatar
rks
are you sure?
I thought the sport lip spoiler uses double-sided tape and the splash-guards definitely didn't require drilling.
Old Jan 3, 2011 | 10:21 PM
gee wiz's Avatar
gee wiz
Originally Posted by rks
are you sure?
Yes, I installed the OEM sport splash guards and OEM sport chin spoiler myself and definitely had to do some drilling. In addition they do also use 2-sided tape to provide a tighter fit. Each splash guard required two holes each for two plastic push rivets. If you look closely in the shadows of the wheel-well in the pic below you can see them as black dots on the splash guards. (Too bad they don't provide color matched push rivets--the black stands out too much against white.)
The OEM rear lip was installed at a body-shop since I had other work being done. I just assumed it required drilling because that was the case with the one I installed on our previous G, plus they happened to have a new 2010 G sedan completed and ready for delivery while I was there. I was told that it required repairs and new deck lid paint due to a mistake in the drilling for the rear OEM lip spoiler by another shop (I suspected it was a local dealer). Someone please correct me if no drilling is required for the OEM rear deck lip.
Old Jan 3, 2011 | 11:00 PM
rks's Avatar
rks
wow, the local dealer assured me that the splash-guards required no drilling since the holes were pre-existing.
Old Jan 3, 2011 | 11:13 PM
LightsOut's Avatar
LightsOut
lip, wing, and splash guards all require drilling. I've installed splash guards and lip and drilled holes.
the holes are nothing to worry about. Its actually optional for the lip. I only drilled like 4 holes and none can been seen or noticed if lip was removed.
ps..
Dang I need to pick up some sport side skirts.
Old Sep 7, 2011 | 12:19 AM
taek's Avatar
taek
dang........
Old Sep 7, 2011 | 06:40 AM
mikelebron's Avatar
mikelebron
100% guarantee you need to drill for the spoiler... The outer holes are beyond the silver stock lip. If you don't drill and use tape, I have seen this it looks like shiate. My fathers dealer did this and you can see the tape since it was not made to be held down by tape and there is a very small gap showing the tape. It was so bad that they used black marker to try to hide The tapes whit color as his var is black. He's had them replace it twice and only after I got mine which the dealer installed it properly he now agrees they are taking the easy way out... Net net do it the proper way.
37
Oct 17, 2020 11:12 AM
rk325
Oct 13, 2015 01:51 PM
Jdragon1974
Sep 29, 2015 09:15 PM
