Weatherstriping pulling off
Old May 29, 2009 | 11:13 PM
x95stacey's Avatar
x95stacey
Has anybody had problems with the outer edge door rubber weatherstriping pulling out of place? I’ve had the car 3 months and I noticed that some areas where one might grab the door to shove it closed are coming out of place. After further inspection, I found that this rubber strip pulls out extremely easy (oops). Unfortunately does not go back in place as easy.
Anybody else find this to be an issue?
Old May 30, 2009 | 03:50 AM
Mike's Avatar
Mike
Take it to the dealer. They will replace it under warranty.
Old May 30, 2009 | 07:36 AM
DrJones's Avatar
DrJones
that would explain leaks from the carwash
Old May 30, 2009 | 01:25 PM
brynomon's Avatar
brynomon
I've noticed the same but it doesn't actually come off... Its just not seated perfect.
Old May 30, 2009 | 01:56 PM
x95stacey's Avatar
x95stacey
Yeah, it does not come off, it just pulls out of place. I know the dealer will fix it but my concern is that it will just happen again and again unless they glue it in place or something. It seems like they would have designed it better so it wouldn't pull out so easy.
Old May 30, 2009 | 02:27 PM
PeterUbers's Avatar
PeterUbers
Yeah -- i had the same thing -- spent about 10 minutes before walking in the doors to work trying to use a credit card to slide this back into place... it's like "breakaway" stunt weather stripping, LOL .. it went back in easily but there are a few places where it looks a bit warped...
Old Jun 2, 2009 | 01:02 PM
Austin713's Avatar
Austin713
there is a TSB on this. mine is getting taken in for this on thursday. its making flapping noises on the highway. even if you dont have a 07-08 they will still fix it. the TSB calls for 3M tape below it.
http://x.infinitihelp.com/forum/loca...atid=77&id=396
Old Jun 2, 2009 | 06:07 PM
Q8y_drifter's Avatar
Q8y_drifter
it's very easy to re-install the strip into place. Just follow the instructions and diagram on the TSB. shouldn't take more than a couple minutes to do.
Old Jun 2, 2009 | 06:40 PM
gugarci's Avatar
gugarci
That happen to my old xS. Although I had the dealer reinstall it while the car was in for service.
Victory
17
Oct 27, 2022 03:45 PM
37
Oct 17, 2020 11:12 AM
MrRiv
Sep 29, 2015 04:59 PM
That_1_Guy
Sep 28, 2015 11:46 AM
