Upper & lower rad hoses sucked flat after engine cools down
Old Mar 21, 2024 | 11:47 PM
TuxedoZ01930's Avatar
TuxedoZ01930
I recently purchased a 2009 S coupe and after only driving a few hundred miles, I noticed the upper radiator hose was sucked flat after sitting overnight. The previous owner had replaced the t-stat & lower hose, so I had my mechanic do a radiator flush, new oem cap and upper hose. Now the problem seems to be worse, after the engine cooled down I checked the hoses and both upper and lower were completely collapsed. When I opened the cap there was no coolant at all in the rad or the hoses, it was all still trapped in the overflow tank (about an inch above MAX line). Somehow coolant is not being drawn back into the rad after cool down. Temp gauge reads normal and heat works normally. Has anyone experienced something like this before? Thanks
Old Mar 22, 2024 | 08:46 AM
BULL's Avatar
BULL
Moderador
Usually this is due to a CAP however you state OEM cap was used.
It's quite possible that if the cap was good then there was a huge air pocket in the engine.
If this was not the case then the cap is bad
If you cannot confirm an OEM thermostat was used then dont remove it from the list of suspects just yet.
Trigga0
Oct 10, 2023 08:41 PM
GXFR
Jun 21, 2020 10:11 PM
Bossman
Oct 14, 2017 08:25 PM
6MT-G
General Tech Questions
Mar 29, 2013 11:48 PM
FlState
Jan 17, 2013 04:33 PM
