Water Leaking Through Tweeters
Old Mar 10, 2024 | 08:09 AM
cg0837's Avatar
cg0837
I would like to know how common is this I had this happen in my 08 G37 and now in my 2014 Q60 after a car wash and if someone knows wether new window seals would fix this?
Old Mar 10, 2024 | 11:41 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Not very common but not uncommon either. The issue could be the door seal, the mirror support seal (the triangle), or the drain channel underneath the exterior A-pillar trim piece. Might want to read through this thread as it offers a ton of info on potential sources of water leaks at the door(s).
Some say you can replace the seals, others say you can adjust the door glass to seal tighter against the rubber. ¯\_(ツ)_/¯ In my case as my car is a 2008 I just replaced all of the seals and called it a day. Leaks solved.
Old Mar 11, 2024 | 01:34 PM
Stylin G's Avatar
Stylin G
Also have the same issue on mine when going through car wash. Not a "ton" of water coming in but still annoying. Dealership wouldn't cover it even when car was under warranty, I think it was $300-ish per side for new seals but never did it.
Old Mar 12, 2024 | 03:07 PM
TheWire's Avatar
TheWire
Been doing this on my 2014 Q60 for years, minimal though and only in certain car washes, I found a car wash that doesn't push water in there though.
Old Mar 14, 2024 | 08:35 PM
beefychicken's Avatar
beefychicken
Z-1 Motorsports sells a tweeter water seal kit. It comes with an adapter and a pint of the OEM ionized water to let you refill the tweeters once the seals are replaced. : )
Ok, couldnt resist,
But yeah - door seal.
bread
Car Care & Detailing
Oct 6, 2024 11:49 AM
Pyrrhus
Jun 2, 2021 12:31 AM
BillyTheMan
General Tech Questions
May 19, 2020 12:20 AM
Huaniitoo
Apr 7, 2018 01:53 AM
Loki123
Canada
Oct 25, 2008 10:43 PM
