3500 rev limit after a clutch and pressure plate service
Old Feb 16, 2024 | 01:33 AM
Aber1758's Avatar
Aber1758
So….. I did a clutch and pressure plate replacement for the first time on my 08 G37 sport. Everything went smoothly. The car starts right up shifts into all the gears, but now I’m hitting a rev limiter at 3500. Any help would be appreciated. I took it to the dealer they have checked ECU and crank sensor all fine. They want to charge me $1000 to make sure that I never touched the flywheel. I told them I didn’t not remove the flywheel, I however did use break clean just to wipe it down. Please and thanks. Also no check engine or codes.
Old Feb 16, 2024 | 11:25 AM
BIL2's Avatar
BIL2
Rev limit
Is there any chance you brake pedal stop moved or dropped out to put you in limp mode?
Old Feb 16, 2024 | 01:45 PM
Aber1758's Avatar
Aber1758
I’ll double check, the car is still at the dealer. I don’t think it’s the problem because all the work we did was so far away from the break peddle. Also there are no lights indicating anything wrong with the breaking system.
Old Mar 15, 2024 | 07:44 PM
Aber1758's Avatar
Aber1758
Now my fans won’t shut off and my windows keep rolling down. Jeez
camerons141
General Tech Questions
Feb 10, 2024 04:47 PM
G37fOrLiFe
Apr 1, 2022 10:22 AM
Harmz
Jan 30, 2018 07:14 PM
Gajewski
Sep 8, 2016 10:07 PM
Dreamon
12
Jan 15, 2015 03:43 PM
