Anyone know how to fix this leak? Video included
Old Jan 15, 2024 | 02:10 PM
spankgo's Avatar
spankgo
One of my water leaks is coming from the corners of the window. Here’s a few photos
of my G37 going through the car wash. Any quick fixes without having to spend another $1000 on this car? Thanks!
Old Jan 15, 2024 | 02:11 PM
spankgo's Avatar
spankgo
Old Jan 15, 2024 | 02:29 PM
ILM-NC G37S's Avatar
ILM-NC G37S
As I indicated in several threads, this is either the corner support seal failing or the drainage channels underneath the exterior A-pillar trim piece are clogged.
https://www.myg37.com/forums/g37-cou...ml#post4291819
Old Feb 5, 2024 | 07:55 PM
RC4G's Avatar
RC4G
It's is not the sunroof drains or the firewall bulkhead plastic connectors, as you can see the water is coming in above the mirror mount and running down the door panel.
The issue is the rubber window corner support seal. I speak from experience because I just replaced mine for the exact same reason.
The mirror base seal is supposed to push up against the door seal but becomes cracked and depressed (no jokes please) with age allowing the water that comes down the a-pillar seal to run inside the door.
Old Oct 10, 2024 | 09:17 PM
Xx.GIPL's Avatar
Xx.GIPL
Did you figure it out? I took apart my door and can’t seem to get the support seal out!?
Old Oct 10, 2024 | 09:49 PM
ILM-NC G37S
You have to remove the entire corner support from the door before you can remove/ replace the seal.
Remove the two (2) bolts towards the top and one (1) nut at the bottom. Once removed, the whole support will lift straight up.
Installation is the reverse of removal.
ABlake54
May 1, 2024 08:59 PM
noskcajj
Jan 24, 2023 03:16 PM
Pyrrhus
Jun 2, 2021 12:31 AM
Ajdinko
Jun 22, 2017 10:25 AM
steven92
Nov 11, 2016 07:26 PM
