Tune without cruise control
Hello everyone I've read lots of fourms here but only just joined as I was wanting to ask if anyone knows if I want multiple maps with my tune (uprev) can I just install the cruise control switches or do I actually have to install cruise control? I'm in New Zealand and it's quite rear to find any G35 or G37 with cruise control here
Also I have volume and Bluetooth phone controls just not cruise control, my only interest in the cruise control buttons is for changing maps, I do not care about actually having cruise control and also I'm not worried about the stereo controls I have if they were to stop working as I don't use them
Hello there Mate, You'll need to add the OEM NISSAN/INFINITI CC switch.
You can use one from a G37 or 370z which I've confirmed that it works.
On a model without CC you would have to do some research on your own car
I could help.
I would need a picture of the back of connector M107 (3rd smallest connector) to determine if your model came with the pins in the harness.
If it did we can tap into those and I can supply the CC switch
If it didnt I can supply pins and CC switch
The figure out where would you want the switch to be mounted.
It might be a possibility to even add the switch to the factory steering wheel with some modding as long as your SRS/AIRBAG/CLOCK SPRING has those wires the we should be in business.
Worst case is you'd have to wire the switch directly
Best case is that you can install the OEM switch in the steering wheel and control your maps from the steering wheel.
I could help.
