Battery dead window didn't roll up mechanic said motor was bad
Old Oct 24, 2020 | 12:17 AM
brikane's Avatar
brikane
I had a mechanic replace a dead battery. He said the window wouldn't roll back up. He tore apart the panel and said the motor was bad. I don't think this was a coincidence because he was supposed to reset the windows. Am I wrong?
Old Oct 24, 2020 | 12:29 AM
JSolo's Avatar
JSolo
Just say no!!!!!
Resetting involves recalibrating the auto up/down feature. The window should still roll up/down when the switch is depressed. If it's not, likely a switch, motor, or bcm issue.
Old Oct 24, 2020 | 12:33 AM
brikane's Avatar
brikane
The windows worked fine before he replaced the battery. How could replacing a battery cause the window not to roll up? It rolled down fine.
Old Oct 24, 2020 | 12:34 AM
JSolo's Avatar
JSolo
Just say no!!!!!
Clarify, what exactly works and doesn't work at this time?
Old Oct 24, 2020 | 12:39 AM
brikane's Avatar
brikane
The driver's side door does not work at all now up or down. It functioned fine before. The mechanic tore the panel off and tried to bypass the switch? To run the motor manually. Now the motor doesn't crank at all. I think he blew out both instead of resetting the window like he should after the battery was replaced. He tried to leave with the window half down when I told him he had to reset the windows.
Old Oct 24, 2020 | 01:08 AM
Birdie's Avatar
Birdie
Not a coincidence. Once the battery is disconnected the window will not roll up . Ground needs to be connected to work. then the window has to come all the way down before it can roll up. If it was disconnected with the window halfway down it will never come up unless you bring it down all the way. Then it needs to be reset. He should of never taken it apart. More than sure if its messed up he is the one that caused it
Old Oct 24, 2020 | 01:20 AM
brikane's Avatar
brikane
Yessir. That's what I told him. Fyi my back won't let me change my own battery. I can't reach the molding clips in the center. Old age sucks and isn't for the faint of heart. Thank you for confirming!
Old Oct 24, 2020 | 01:22 AM
Birdie's Avatar
Birdie
Oh that's sucks. I was kinda wondering why you would have someone do that for you but makes sense now. Best of luck
Old Oct 24, 2020 | 01:50 AM
JSolo's Avatar
JSolo
Just say no!!!!!
@Birdie, I don't remember having to roll the window all the way down to have it come up at all. Maybe it's model year unique - mine was a '12 sedan. It's been 2+ years since I last replaced a battery in this car so my memory is a bit foggy. If the window doesn't go in any direction at this point then there's definitely a problem.
sunnyice
Mar 4, 2014 08:54 PM
winkerbean
Jan 13, 2013 02:09 PM
Middlefingaz
General Tech Questions
19
Mar 4, 2012 03:15 AM
Emon Crew
Sep 5, 2011 01:59 PM
teekaywhy
Nov 8, 2010 09:58 PM
